USAF Willys DJ-5 Air Police
Here is a small project I started while waiting for parts to dry during my M60A1 Franken-tank build.
It is a Willys DJ-5 Dispatcher Jeep. These were originally built for the USAF to use in non-tactical roles around base. They were built starting in 1955 and were basically a M38A1/CJ-5 with a new body. They were civilianized with only rear wheel drive, standard steel front bumper, large rubber bumper on the rear, fuel tank relocated to under the rear between the frame rails, civilian wheels and tires, and a few other changes.
Later versions were made by AMC with an extended grill due to a larger engine. They were later used by the USPS as delivery vehicles.
Apparently, later versions were also used by the US Army and USN for similar purposes.
I haven’t found any pics of them in USAF service, but I did find a drawing of one.
I have also found pics of similar M38A1 Air Police jeeps, so That is what I am going with.
I found a DJ-5 file on Cults3D and resized it to 1/35 and printed the pieces for it. I added these to an AFV Club M38A1 tub, chassis, and front end. I had to modify the tub by removing the gas tank under the driver and rebuilding the floor w/styrene, leaving the tool box under the passenger off, and leaving off the levers for the transfer case. I sanded the 24v battery box cover on the engine cowl off as well. I also adjusted the door openings since the 3D file had rounded openings like an M38A1/CJ-5. The DJ-5 had angled door openings. I also added the seat mounts from some left over PE parts, and added the vent covers on the front sides.
On the underside, I removed the front differential and replaced it with a styrene rod. I also removed the transfer case and cut up the rear axle to relocate the differential in the middle, as opposed to the 4WD offset. I rebuilt the drive shaft to fit as well. Lastly, I added the fuel tank behind the rear axle and added a filler tube to it coming from the filler cap on the right rear.
Here it is all mocked up to see how it will look assembled with rear door open and closed.
Here are some of the other 3D printed parts. A battery to add in the engine compartment (which will be plumbed), tires (1950s chevy 5-bolt rims and '50s tires), front and rear seats, rear bumper, and a siren. The rest of the tires are currently printing.
I plan on marking it up as a USAF Air Police jeep (like above) in USAF Strata Blue with yellow markings similar to above. More to come later.
Awesome looking project. Here is the markings guide for the M38a1 from 1958 which should be similar to the DJ.
And here was a video I did helping my buddy do the USAF markings on his 54’ M38a1 when he was restoring it.
https://youtu.be/N9WQcwDlBfg?si=dQCzZ_3JKyGenZ5l
Cool project Gino! Good luck with it!
Thanks Dave. Great references and awesome looking M38A1. Your friend did a great job on it. I have a set of decals from an MMK M606 in USAF yellow. They have the “U. S. Air Force” and numbers, but no “For Official Use Only” decal. I can’t find one anywhere either. I guess mine will not be “For Official Use Only”.
Thanks Pawel. It has been fun so far.
If you need that “for official use only” inscription, I could draw one for you in CorelDRAW. Then you could try to find someone to print it for you.
Thanks for the offer, but I am already working on it. The yellow printing is the issue. I’ll figure it out though.
The guy that prints decals for me always points out, that the yellow is unfortunately translucent, so for yellow patterns he always suggests white decal, and an indentical yellow one on top of that. Works pretty good.
Dave, a question for you. On the DJ-5 drawing and M38A1 pic I posted (which I just noticed have the same numbers), both have the U.S.A.F. and numbers on the hood, and U.S. Air Force w/numbers on the doors.
On your drawing of the '58 markings, the U.S.A.F. and numbers are not on the hood. Is that correct? Did they delete them on the hood?
EDIT: I may have answered my own question. I found these Air Police vehicles from the same timeframe with the door markings only.
A buddy of mine had one of those old mail jeeps. He was driving it drunk one night with the doors open and fell out. He jumped up and chased it down the street until it hit a telephone pole, jumped back in and drove home. He closed the doors after that! Wayne
The extra hood markings were applied at the discretion of the local base commander. A lot of it was carry over from the old days where the vehicles were originally Army vehicles serving with the Army Air Corp, and once the Air Force became a separate branch, they simply added an F to the end of the hood U.S.A. By the mid 60’s this “tradition” had died off like what’s in the pictures above.
Great. Thanks for the clarification.
Progress continues. I was able to get some paint and decals on it. I also got the seats and wheels on it.
I painted it with Tamiya AS-8 Navy Blue spray. From what I read, it is the closest model color to the USAF Strata Blue used on ground vehicles. I think it came out well and looks good.
I added the US Air Force (no “For Official Use Only” :frowning: ) decals and had enough to piece together bumper numbers as well. The interior are left over gauges and placard decals, along w/a Jeep data plate from a Tamiya Willys MB (close enough). The white decals on the inside of the windshield and rear came w/the USAF decals as well.
I also am taking a Tamiya WWII US Army MP figure out of their MP Harley set and redoing him as a USAF Air Policeman. Here he is, with an original M16. He will get the bus driver hat as well.
More to come later.
Looks outstanding and the Strata Blue turned out great.
Thanks Dave.
Here is a bit of trivia. Does anyone know why the Air Policeman has an “original” M16, not an M16A1?
Yes, because the Air Force was the first branch to order the original XM16 in the early 60’s. The Army didn’t adapt it until a few years later and added the forward assist.
Yup, Gen Curtis LeMay (father of SAC, AF Chief of Staff) was the champion of the M16 and wanted it for the USAF. The Army wanted to continue with the M14 and said the M16 was far inferior. LeMay won and got the M16 approved. It was later shown that the Army rigged the tests to favor the M14.
Love it, Gino. Cute little machine and fine work you did! Had to dig a bit but I remembered some pics I took many moons back (2004) in a huge scrapyard south of Madrid. 94 prefix (on Spain’s typical style license plate) would point to a USN machine so most probably it saw service at Rota.
Thanks Javier. Nice find. Looks like it is in decent shape.
Great build.
