You have a pre-2001 styrene kit with PE and barrel? What is it? Kind of misses the point of the build.
How “much” of a kit does one have to build to earn a badge for this campaign? If I build ONE vintage 1/35 DML figure from an old figure kit, would that qualify me for a badge? Or do I have to build the entire kit of four DML figures? (I don’t believe I have all four figures due to kitbashing back in the 1990s. I may have some leftovers to make a single figure perhaps). Thanks in advance.
No, but Gunze Sagyo released kits with those parts as far back as the 80s.
https://www.scalemates.com/kits/gunze-sangyo-g-703-jagdpanther--185972
Sorry Peter but you have to build what comes in the box. If it’s 4 figures, you have to build 4 figures. If it’s 2 planes, you have to build both planes.
If you want to build a collectable boutique Gunze kit for this campaign, go for it.
I’ll be doing the Matchbox Strikemaster. Decals look good. Might do the New Zealand scheme.
And if I have time, there’s also this Hasegawa Babs.
OK, thanks for the answer.
Cool. The Mk80/86 has a lot in common with the AT-37.
Both pretty decent little attack planes. Should be a nice quick build.
I’ve got an ancient Italeri Land Rover kit that I bought nearly 50 years ago - is that old enough? ![]()
I’m planning on doing it as one of those safari-park rides, with black & white zebra stripes. Should be as OOB as can be, other than NOT using the old perished decals!
Please add me to the group. I’ve got the Monogram 1/48 P-38 Lightning whose origin is from 1964. I am using this in another group build using the same materials and techniques from the same time frame … tube glue and brush paint or spray can. I’m looking forward to it. Built it back in ‘72.
Trimaster kits like the Fw190D-9 came with PE and metal gear struts back in the late 80’s. There were probably other pre-2001 kits that came with PE, resin, and/or white metal too. Probably need to decide if you want to limit it to kits before a certain date only, or also limit it to plastic only kits, because aftermarket in kits goes back longer than 25 years.
I love this idea! Looking forward to Build some ESCI or Matchbox kit(s).
I remember building that kit in the 70s! Took a lot of clay in the nose to avoid being a tail-sitter…
I know there are ribbons for these campaigns. At least I think you still do that. How about a device on the riboon for the person who submits the oldest finished kit in the alloted time? Like an hourglass or a falling leaf.
I like that idea, a lot. Unfortunately, when Jim awards the ribbons it is a group action, so it would be impossible to give one person a different ribbon.
He could treat it as a separate award.
Impossible - no. Asspain? Quite possibly.
I have Dragon’s JS-1 (1995) potentially for the campaign BTW.
The one you linked is from 1963.
There is also newer Revell Lancaster from 2007.
