The problem with the Academy kit is the ride height is too high. The axle/spindle on the roadwheel arm should be just under the hull.
The hull looks the same as the Desert Warrior. Possibly use this for early trials version when the new turret was on the old hull and use the hull conversion for a Desert Warrior.
