I have that one also and as you say, a true gem. Looks like it has gone together very well. From what I can see, your scratch item, looks the part!
I may have to remember that trick.
I started a few Bremer walls today. Still many to go but I am happy with the initial results. Roughed up the edges and applied the slightest bit of texture to represent the flaky nature of hardened aged concrete. Then I added hoops with .8mm lead wire.
Wrapping up this B2. Hard to get good photos of it due to the size
I have finished construction of the 1S91 radar vehicle (KUB AA system) :
I received the kit couple of years ago as a BD present from my modelling buddies and built it within a week.
It was a fun week!
Angel
Carved a brick wall out of XPS foam. It’s looking good, but there’s still a long way to go.
Finished my Nagmachon…
Spectacular presentation Bert! You must be exhausted after this build, whew, that’s purty!
Cajun :crocodile:
Thank you very much :+1:
Bassackwards veneer attachment…
Was originally thinking of painting the base sides, so adding veneer was a complete afterthought. Color selection, base handling and attachment, all done in entirely the wrong sequence — extreme care had to be taken while handling as not to disturb the delicate groundwork and fence assembly.
So here we go. :construction:
For starters, the block height was smaller than the veneer width by 1mm. Stirring sticks attached with Elmer’s Glue-All worked perfectly as shims. Here, using a clamp for easier handling.
Here’s the roll of veneer (non-ironing type) from Amazon. … Emphasis on “roll,” as it needed serious uncurling before I could work with it.
• Walnut Veneer Edge Banding, 1-inch x 25ft (1mm thick)
• Scotch Super 77 Spray Adhesive
I cut a rough band and reverse curled it with a clamp overnight which flattened it nicely enough. Here’s the veneer scribed at 4-inch increments for corner bending and prepped for Super 77 spray.
The next step was by far the scariest. I sprayed (decanted) a puddle of Super 77 onto a piece of paper. Then, I hand brushed it onto the block sides taking care not to disturb the edge greeblies.
Went for it anyway. …:game_die:…:game_die:
A couple of my scribes were not exactly perfect for the wrap, but only required minimal corner trimming and sanding. … Got lucky! :sweat_smile:
Clamped the hell out of the veneer and et voilà!
The next hold-up… I have a nameplate on order which is gonna’ take forever to get here. Still, a lot closer to finishing now.
Thanks for having a look!
—mike :hammer_and_wrench:
Finishet my “Sturmy” last weekend.
Look at this post for more pictures.
@Dioramartin, waddayathink?
Hi Erwin I think (a) WOW! Excellent job, and it looks like it weighs 68 tons (b) that’s what an RFM Sturmy’s supposed to look like (c) I’m no expert but I’m more than willing to believe those camo shades are 100%. I was surprised you’d kept the clear roof though…reasons? And only because you asked me, you just know what’s coming :laughing: - dust/dirt?
Thank you…
I simply kept the transparent roof, because it is there. So, like this, you can see something of the interior…
And dust/dirt are my nemesis anyway because I have not enough cabinet space to put everything in there. Specially the big planes and my Ziu dio…
Still looking forward to your rendition… :smiley:
I have begun tackling the MASSTER camouflage scheme on one of my two completed M551 Sheridans:
[grid]
Nice!
There’s something about that scheme that is so good, Brian!
Thanks Terry; yeah, there’s something about MASSTER. Perhaps it’s because I’ve actually seen it in the flesh so to speak. I thought the Brits were ahead of the game with the black and green, then on my very first exercise in the Big Boys Army, I encountered MASSTER; blew me away!
Wow, that would take some concentration to do. Looks really nice.
Thank you, Steve. It takes concentration, yes, but overall it’s rather easy: a ruler, a pencil, an x-acto, and trace lines! Nightshift has many videos on this process (and there are plenty others).
A few finished models seeing that its still spring like weather in the northeast these days lots of painting gets done.
