I decided to compare the Rye Field T-34/85 kit barrel with an Aber aftermarket barrel I already had, and noticed the Aber barrel was shorter. Which barrel is the proper length?
Based on respected reviewer Terry Ashley’s comments, and assuming you have the barrel #35 L-09, the Aber barrel less 4mm inserted in the mantlet is apparently the correct length.
https://www.perthmilitarymodelling.com/reviews/vehicles/aber/aber35l09.htm
