There are a few possibilities. You could use an Urdan cupola as a base and add the proper bits. I think the M103 used a similar one as well. Accurate- Armour does one. Include it with your final (ever) order from them and shipping is free!
I have one from AEF Designs but it probably scales out horribly,
Is this what’s needed?
Welcome aboard!
@coho_tech Welcome to Armorama! Enjoy!
Coho, welcome to the forum!
I got the RWS: on the M48, it is a progenitor of the Urdan Cupola, but is in fact an RWS operated by the TC from inside. My dad (LTC, Commanding 72d Tank) said it was a bit like rubbing your head and patting your belly at the same time.
I sourced a 3D part printed by a gent in Greece. Exceptional quality!
Oddly, my ODS M1IP had the then current mount for the M2HBMG, and the manual controls were placed nearly identical to the M48. I learned to use the electric “pickle” that hung on a peg affixed to the turret wall, but that could be disengaged for freestyle!
Two other things to do to convert the M48A1 to M48:
Add the brackets to the turret roof for holding the MG mount when taken off the cupola. Unfortunately the 3DMC set doesn’t include them.
Change the driver’s hatch and periscope arrangement. The DML T54E1 kit has the correct M48 configuration, if you can find one. I bought an upper hull sprue off eBay. If not, putty and Evergreen . . .
KL
One should also make the cupola ring on the turret smaller in diameter, so the Chrysler cupola fits exactly in the ring, shouldn’t he?
It should be checked, at least. I was thinking of that but I couldn’t remember whether the DML kit had it right or not.
KL
It has the larger diameter ring for the M1 cupola.
Another one, but looks incorrect…
I think you asked me to check that last year - I have not forgotten. I just haven’t had time. Every time I pass through Ft. Carson now it’s on the way to some place much farther away.
