1/24 Lancer Evolution V WRC shelf queen
Had this kit sitting on a shelf partly built for far too many years now.
The body was painted gloss white and then left as i lost the decals and couldn’t find any matching after market ones available.
Eventually i did find the decals again so while i had the spray brush o out decided to mask up and paint the red.
Masking wasn’t quite as good as i hoped and got some spray underneath in a few spots, couple can be seen here.
Once the red had dried for a couple of days i did a rough mask and resprayed the contaminated areas.
The interior is mostly built so will get some photos of that later today.
Door cards and dash. Want to add a bit more detail to the dash but not sure how to go about it yet. Need to see if I can find some decent (or even any) photos of the real car dash.
Seats. Rear side texture/colour is a decal on both.
Chassis undersides
Chassis upper with some interior detail.
Keep going with it, interested to see your progress.
Repainted the dash so it wasn’t just pure black.
Used Lifecolors “Shades of black” set or whatever it is actually called, with deep cockpit, dirty black, and burned black.
Areas where decals were going were left gloss black. When I went to apply the three dash decals, the speedo, Mitsubishi logo , and what I assume is some kind of timer screen, they disintegrated. So now I have to try and come up with replacements. Fortunately I have decal printer film, both inkkjet and laser compatible versions, I just need to create the artwork.
In the meantime the remaining decals have received a coat of Testors spray decal bonder and appear none the worse for wear after it.
I have also scanned them in the highest resolution I could in the event they still fall apart. The only issue I would have printing from the scan is the fact the backing paper is blue, which means a lot of editing to get rid of the background colour first.
Nice work !
The different shades of black is a great idea. Brings more depth and realism to it.
First experiment with the coated decals.
I used the seatbelts and applied them to some thick aluminium foil that had been primed and clear gloss coated.
The pair on the left split in to top and bottom halves and had to be realigned, the ones on the right came off in one piece. Still a far better result than the complete disintegration of the dash decals I first tried.
They took an extra long soaking before they even began to come off the backing paper, so I added some Gunze Mr Mark Setter before laying them on the foil.
It took careful application of force to get them to slide off and I pushed from the top then as it bunched up ,slid the bottom part down a bit, then repeated. Tried pulling straight from the bottom on the first one hence the breakage.
I will cut them close and paint the back of the foil red before I add them to the the seats, and then do the lower harness sections.
It does give me some hope that the larger exterior decals may still be useable, though the additional work to get them to release from the backing paper will require extra care to avoid breakage.
Interior is coming along. Got the fire extinguisher decal on without too much trouble. Even with the extra thickness of the testors decal coating they settled down ok with some decal solvent.
One of the seats has the belts on now. They just disappear to nowhere. Not sure where the ends would be secured in the real thing. Seats are only dry fitted at the moment.
Interior is mostly done. Still need to replace the dash decals and install the dash.
Seats are installed. Seatbelts went ok but the decals did come of fin several places as I tried to cut the foil backing down to size. Some touch up in spots is still required.
Started working on the exterior decals while the body was off. That wayy if there were any big screw ups I could respray without too much hassle.
They have gone on pretty well after their coat of spray bonder, the biggest issue so far is the roof Number 1 decal which has a large amount of decal film around it that has noticeably yellowed. Doesn’t show up as strongly on camera but is quite distinct in person.
You’re getting a fair degree of push-back from this shelf-queen Iain, great effort to keep it rolling and find some alternative solutions! I’ve had a whole year this year just trying to reduce the WIP list and it’s a great feeling to get them in the display cabinet, this one will be no exception. It’s looking very nice.
Cheers, D
