Buff,
I think you may be on to something. Kinda hitting the wall with my Stalingrad dio.
Well, my T-37a is a “shelf Queen”, but i freed up some space on the desk so… Here is a wee update, I attached both floats, constructed a ROUGH turret base compartment, minus the curvy drivers port. Pre fitted the turret and started other engine deck details.
First, thank you to all those who added links to T-37’s.
Next this is confessional post. I screwed up BIG TIME. There is ZERO that can be done to correct this error now. So I am just gonna finish the build and make my peace with it. A couple of these shots are of the 7.62mm Brass MG that I made for it. Still thinking about a 12.7mm MG but we will see
Work continues, and I found a version that ROUGHLY corresponds with my foul-up.
I added a water break to the front and am TOYING with extra armor. But we shall see
Well I’m still liking it - what was the screw-up anyway?
Okay Dio here it is. Although through research of actual vehicles, I am not as “wrong” as I first thought. The error is in the rear decking. Most variants show this as a long slope up to the turret structure. Mine is stepped. Again not a huge error but still I am aware of it ![]()
Wheels, Torsion/Spring assembly. Not gonna lose sleep over them. They will be seen in a water vingnette
Here are some details I recently added. A new stowage box, wire guards, (not finished), and the torsion bar mounts. These are a WIP, meaning you cannot see the brass rod that runs through the vehicle and will carry the weight of the build before it goes into a water dio
Scratch-building at its finest, bravo
Dio, MANY THANKS. Frankly I just got bored with 1/35th.
Hello Whitney!
Great job on that scratchbuilding!
It’s kinda pity that I missed your build for all these years… Because I’ve got something that I think could help you a lot… You’ve done most of the work for now, but maybe you can still find some use for my input? You see in Poland we have a publisher that issues paper models since 1957… And many years ago they issued a model of T-38, right smack in 1:25. If you like, you can view this complete model here:
If something like this is helpful to you, there are also paper models of a legit T-37 out there (also in 1:25) but I can’t find the scans of them right now. I think they can be very helpful for scratchbuilding, because you can just copy many parts, or cut them out and trace around them - that could save a lot of mrasuring.
Anyhow - good luck with your build and have a nice day!
Paweł
Paval, That is exactly what I did. Although I made a major “foul-up” along the way. She is still coming together nicely. THANK YOU for the input.
So yes these are just “showing off” detail pictures. For the last 45 years I have added a stowage box to my builds. If I built a model of a stowage box, yes I would add a stowage box to it. Old habits are hard to correct. You’re looking at the brass wire nails and locking lapse
I would rather die than use Photo-etched ![]()
OK I’ll bite - where’s the prop from? ![]()
Travel back in time with me. Academy released a 1/25th scale US GPA Jeep. It was a horrible kit. I bought two, one ended up as a gift, the other into the “parts” bin. 15 or 16 years later… ![]()
So I have been battling the undercarriage, super details and some minor painting.
Mostly the return rollers, still WIP, but making great progress
Scratchbuilding is an artform in intself. Your build is masterclass. I am looking forward to follow your progress.
