Here is a Shapeways printed LM 5 in 1/32d scale,
I’ll post the WIP pictures a little later.
Sharp looking LM with interior!
Looks great!
Fantastic work! I love all of the detailing and paint work. The base and figures really top it off!
Thanks for the positive comments , I’ll post a few pictures at a time of the construction process with materials used. The initial set of photographs show the incorrect color of the 5 mil kapton foil which was corrected later on,
Oh wow!. Nice work.
Steve, glad to see your work here in Real space section. I had seen it few times at ARC but thanks for sharing it here also.
Looking at your LM pic with astronaut figure, I did not realize the exit way was in the bottom where the astronauts had to crawl down and then out.
I wonder how many times did they hit their space suit or backpack trying getting in and out that thing and if it caused any problems? ![]()
Anyway, learned something new about the LM today.
That’s absolutely stunning! Fantastic work.
Jim
Super detailed. Outstanding model
Stryker 45, Jim and kosprue one thank you so much for the positive comments, I’ve been out of modeling for quite sometime so your interest really makes this worthwhile. I’ve built quite a few LM’s over the years and none really pushed the envelope so I figured it was time and this is the result.
I’ve learned quite a bit about the LM during this build and developed new construction techniques I’ve not used on previous attempts . Stryker 45 that egress hatch does seem impossible to pass through with all the gear on doesn’t it but can you imagine getting dressed inside prior to exiting!
At this point of the build the 5 mil kapton on the bottom of the descent stage is the wrong color.
Steve, was there any temptation to say the color discrepancy wouldn’t be noticeable enough to fix?
Thanks!
Wanna see dumb?, all the other builds were the correct color and on the ascent stage the same burgundy areas are incorrect and yes there was
So, am I reading this right, you painted all the foil work on the descent stage? And all the panels on the ascent stage? Hand riveted?
Outstanding!
