I have a Tamiya Panther I’m building but I have a spanked Dragon Panther with tge turret and gun. I have read the Tamiya Turret is incorrect dimensionally and the gun barrel is either too long or too short. Thanks
What area of the Tamiya Panther G turret is allegedly inaccurate?
I can do a few basic turret checks versus references, if I know what needs checked.
That’s a great question I have seen people state the dimensions are off and the gun barrel is incorrect. I have a spanked Dragon Panther with the turret and gun on the sprue still so I was going to use at least the gun barrel.
People are generally talking about the Tamiya’s Panther A.
What is a SPANKED Dragon Panther?
With zero specific’s I wouldn’t have much concern with the Tamiya turret.
Just for kicks, being an x-Panzer Police , myself, I pulled a random Tamiya Panther G from the stash to check vs my best available references.
To my knowledge the main gun is the same length in Panther’s D, A & G. If that’s not true hopefully someone will comment and provide objective evidence.
So we’ll use Panzer Tracks for Panther D to evaluate the Tamiya main gun.
Tamiya main gun over laid on PT, base of main gun alignment accordingly with mantlet.
Appears checking with my Armor Research Company 1/35 ruler the Tamiya main gun is about 2.5 to 3 scale inch too long.
One could cut the muzzle brake off, chop 2mm off the MG, reattach the muzzle brake and call it good. Or one could consider ~2 mm too long gun irrelevant.
I have to use the Jentz book for G measurements as that’s the best reference I have available for checking.
Tamiya turret looks spot on bottom dimensions to me with the basic over lay check.
Using the plans and my Armor Research Company 1/35 ruler I checked the dimensions indicated in pencil arrows
While this isn’t a perfect micrometer check, everything seemed within 1 scale inch to me with one exception.
The Turret height seemed to be slightly low by about 1 to 2 scale inches. My measurements aren’t perfect so I consider under 2 scale inches irrelevant. If the turret height is off it’s probably ~ 1 mm low.
That’s the best information, I have available at the moment. Maybe someone else can comment to a more exacting degree.
FWIW - I wouldn’t worry about the turret much but I’d probably chop 2mm off that Tamiya main gun most likely or use a different barrel.
HTH
PS - the Tamiya Panther A turret is definitely off on several areas. It takes serious surgery to fix it.
Yes, i will be the “wet” blanket. If I was unsure of something like “barrel length” I would just do the math. Euclid was right. Math doesn’t lie
Thank you very much for the great detailed jnformation
Oh come on, If the market loses 50% and then gains 50% your good.
Ooh. Misunderstanding the way percentages work. If the market starts at 100 and loses 50%, it’s gone down by 50 (50% of 100), so it’s 50 now. Now, if it goes up by 50%, that’s 25 (50% of 50), so it’s up to 75, and you’re down 25 from where it started.
Sean,
You’re correct of course but I’m 99.995% sure TopSmith was making a satirical comment.
