I remember getting this kit for a present on my 12th Birthday. I proceeded to build it horribly. Then probably burned it.
Fast forward to 2026. I find the a copy of the same kit on ebay:
As you can see, it was in pretty rough shape. The trailer was glued together and had eaten into the plastic. So what i decided to do was age the trailer and make the glue look like some kind of roofing tar or rubber.Also the top of the cab around the horns and lights. It was also above the drivers side, so in sanding, I lost some rivet detail. Scratch built the cables (Big Whoop!!) and the tire rack under the trailer. Decals are from: https://modeltruckers.com/. I highly recommend them. My only complaint would be that the decals didn’t match the scale of the photo on their site.Rear door pays homage to original kit. Comments and critiques are welcome.
Here is the image of the decal size from https://modeltruckers.com/
