A MISSTEP AND A QUICK FIX
Here is the oft-reproduced (in this blog) profile of “Luscious Lady.”
The profile comes from my Osprey history of the 303rd
and I worked closely with the artist, Mark Styling, on the research for the profiles. The LL profile shows the de-icer boots on the wings and the tail leading edges, and hey, you would think that since it’s there and I researched it, it’s probably right, no?
Well, NO! So, when HG sent me these “How’s this?” pair of photos yesterday
I realized he had gotten ahead of me and I had to act quickly. I knew that Styling and I had made a mistake in one area of the book profile research.
Here’s the thing. It’s pretty clear from period 303rd photos that fairly early on the Group (and other similar groups) made the decision that the wing and tail deicer boots weren’t worth the trouble of maintaining in combat. They were removed, and the bare aluminum was in some cases – not all – covered with field-applied OD.
This crash photo of the 303rd’s “Thumper” PU*F, shows this quite clearly.
You can also see it on “Vicious Virgin”
especially here in this great formation photo of the A/C taken by David Shelhamer
It’s obvious from some of the early G models too, such as the 427th Squadron’s “Spirit of Wanette.”
where it’s pretty clear the paint was wrapped around the leading edge in the same way we see on many “Golden Age” US Navy aircraft where the chrome yellow was extended to the bottom of the aluminum-colored wings.
You have to be careful on timing, however. Look at this picture of “Spirit of Wanette” after the 12/20/1943 mission to Bremen, where the deicer boots on the horizontal stabilizers have been taken off, and not yet painted over, as in the above photo.
Finally, as this famous shot of a B-17 going down over Berlin shows, sometimes the aircraft flew with no overpainting of the deicer areas at all.
“Check your sources for the particular aircraft you are modeling,” as they say.
HG promptly addressed my error and you have these shots of “the particular aircraft you are modeling” to show how we are treating this:
(I’m told the little circle behind the boot area in this shot will disappear when a flat coat is applied.)
The below shots show further (beautiful) work on the rudder and tail.
And yes, you see some aluminum shining through in the deicer boot area at the top of the vertical stabilizer. Artistic license, because some photos show this kind of thing.
HG will be applying decals to this area next, but I caught one of my mistakes on what areas of the national insignia were painted grey, not white.
The sidebars were white: it was the stars that were overpainted in a light grey on the fuselage and upper wings.
Look at the above formation shot of “Vicious Virgin” again, and this decal sheet, to see the peril of relying just on memory.
It will be great seeing the “Triangle C” finally go on the tail of this build after, what, 7-8 years now?
