1/48 Bomb Truck
Looking for either/or … GMC M27 Bomb service, Gaso.line GAS48067K … GMC CCKW 2,5t 6x6 recovery No.7, MP Originals Masters Models 48011
anyone
Curious if you’ve given though to scratching either of those.
Probably cost as much or more to buy what I’d need to make it. I beam, winch, chain, hook (pastic sheet I got.) Like cooking … have to buy a jar of something for 1/8th of a teaspoon… the rest goes in the back of the pantry until your next of kin clean the house out after you die.
If it’s bomb service you need, forget the Wrecker Set 7 - that was a maintenance rig for vehicle repair/recovery. As for scratching, the bomb service rig is mostly a single I-beam size so only one pack of Evergreen. The hoist pully rig is more of a challenge, but can be built up from sheet carved to shape. Either way, good luck!
I have the Gas.oline M27 bought from France, very very fragile, with a lot of resin flash, for the price, not worth the shipping to the UK.
If you have access to a resin printer (or access to someone who does) the Cults 3D may be of interest.
Federal_606 has a number of items such as GMC CCKW 353 m27(b1) bomb service body including the frame, winch, & movement rails at under $2.50, well worth it.
I have bought some of his STL’s but are still playing with my resin printer, & I have seen some of them printed at a Major UK hobby show, so they are usable.
I’d still bet a scratchbuild wouldn’t be that daunting:
I’ve bought several of his designs and they are not bad at all. But they are designed to fit his own chassis, so you have to do a little fiddling to the frame rails on the underside of the bed to get them to fit a plastic kit. No biggie, but best to be warned. And it’s 1:35 scale, so whoever prints it needs to scale it down in their slicer software to 1:48.
Field-made trolley
Sort of. Standard bomb lift with customized cradle.
Note T shapedhandle.
I should have written field-made craddle…
??? S’pose I shoulda posted photos…
Looks like the MP Originals Masters Models | N° 48011 | 1:48 might be the best option. I like the simpler design.
I’ve yet to find a period picture of it used as a bomb service truck…But it was used for the Ordnance maintenance shop truck version
Stumbled upon this looking for something else. Bomb truck was M27.
Side bar: Would airfield support vehicles (tanker,bomb truck, crew transport) have had the red/amber corner refectors fitted. I’m talking 8th/9th AF in England, late 43-44. From what I know they were easily removable. Im thinking by that time collision avoidance would trump light security. (I could see 9th AF/ Army vehicles on the continent after Overlord not wanting anything shiny.) Period photos show the mounts but cant tell if the lenses are in. Also, lens colors? I seem to remember red on rear corners, amber ones on forward corners (or is that DOT/OSHA drivel?) Lastly, the fuel tankers had a large CO2 extinguisher mounted on the front, passanger side , tanker body. OD or Red?
