Hello, does anyone have any good ideas on making display stands for WW II 1/48 scale aircraft? I want to display aircraft flying. Thanks in advance
My thought would be to find a photo of the aircraft you’re building in flight that you like ie landing or cruising etc. Make a L shaped base. Digitally fix the background to remove your plane and attach your model to the vertical side via the wing tip.
The other is the standard pole through the belly look.
