Have done a bit of work, on the Revell '65 Mustang Fastback.
Undercarriage is almost done. Still a few bits, on the front suspension, that needs to be assembled.
The engine is almost done, as well. engine kept in satin black, gloss black and blue. The carb and air filter is just dryfitted. Will have to wait and see what clearance I have once the body is mounted. The filter sits quite high, since it is a solid piece of metal and sits on top of the carb, instead of over.
Not quite pleased with the wiring I have done.
Body was first primed, then base coated in Gravity colors titanium white, before adding several coats of Gravity colors Yamaha bluish pearl.
The bluish tint is not that easy to see though, before the clear coat is added.
Did a little test on a spoon. Not as bluish as I would have liked to see.
Wheels have been painted too. The Chevy Nightfall grey is darker than the images suggest.
