Т29Е1 from HobbyBoss or a parallel instruction with painting technology development
For reasons that I will explain later, it so happened that almost immediately after the assembly of the ARL 44, the American heavy tank T29E1 from HobbyBoss was also assembled. The tank, by the way, is also extremely brutal looking. Similarly to the previous model, I see no reason to post a review of the box or the progress of my assembly, but I bring to your attention again a parallel instruction, i.e. concentrate of impressions from the assembly, fixed with a fresh mind.
With the French tank, I was glad that its rollers were small, and the tracks were large and there were few of them. Here God took revenge on me. The rollers are normal: there are 18 main and 7 supporting ones, all doubled. All are given with a margin.
But there are 240 tracks, of which 226 will be used. There is a reserve, but it is small, and they are fragile. Each track has 3 feeders. Plus there are two more connectors, one on each side, and they are different. They are given with an even larger margin (248 each), but very small.
I must say that the eminence and experience of the manufacturer affects. If Amusing Hobby has a dime a dozen jambs in the instructions, then HobbyBoss has an order of magnitude less.
So, let’s begin:
  1. At step 3 of the instructions, I would recommend trying on the top and bottom of the case in order to clearly understand what really needs to be cut off and why. There is a risk of cutting off the necessary guides.
  1. When assembling the undercarriage, one must be extremely careful and realize that in the instructions the hull bath is given upside down. For example, I’m used to keeping parts in the correct orientation.
  2. The second model in a row in which the headlight lenses are given by opaque parts. One recalls a bearded army joke: “Clog a window with plywood and paint it with transparent paint.”
  3. In parts B3 drilled 0.8mm mounting holes for part B12.
Maybe not necessary, but it’s better.
  1. When gluing parts B27, and there are already 4 of them, the main thing is not to make a mistake with the direction of the comb.
  1. When gluing part C57 (C58) you don’t have to worry about the back gap, it will then close at step 10.
  1. I did not glue the C14 part - it looks too clumsy and foreign.
  1. The instructions do not indicate the sequence of gluing the overhead grilles. I started with the front ones. I bit off both, processed and it became not clear which of them was which part - they are completely interchangeable, the difference is only in the tilt of the blinds on the grilles.
But the pairs of parts D4 + D11 (by the way, there is a typo) and D5 + D12 are not interchangeable and can only be glued correctly (with the correct orientation of the sides with loops and handles). Having glued them correctly on them, decide on the slope of the blinds and at the front grids.
I have them oriented in different directions, but the front grids are almost completely hidden under the tower, so it’s not particularly visible.
Although making the grilles a solid plastic part is a bad form.
  1. In steps 8 and 9, it’s time to get serious about how you’ll be making the many staples - detail A7.
Look at the frames - how small and thin these staples are, i.e. fragile and easily lost. And you need a lot of them: there are 7 pieces on the boxes on each side, 12 more pieces on each fender, for a total of 7 * 2 + 12 * 2 = 38 pieces. And there are 48 of them on the sprues, i.e. There is a supply, but not that big.
I will add to this that the places of their installation are marked very faded.
If you do not have wire cutters, similar to these
it is better to immediately take the wire and bend them yourself. And drill out the attachment points.
  1. In the same place: there is no need to first insert the B11 part into the B24 parts and then glue it, as the instructions recommend. B24 parts have such huge holes that B11 can be inserted after gluing. You can check on a free pair of these parts.
  2. In step 10, I reamed the barrel of the machine gun and a little muffler outlet. But this is my personal initiative.
  3. It took me more time to implement step 11, assembling the tracks, than the rest of the tank.
Locks T2 and T3 refused to stay on the pins of the track and flew off at the slightest movement. As a result, everything fell apart. I had to flatten these pins a little and only then connect them. And they are thin and fragile! If you squeeze too hard - they will not fit into the holes, if you squeeze it too little - they will fly off.
It is also important that the sections belonging to different tracks must be mirrored. Having installed the next 5 tracks in the conductor, I looked very carefully at which side to insert which connector. And still, I was wrong once.
  1. The turret of the T29 tank has a very rough molding texture (By the way, advise a good photo tour of the tank. I didn’t find it. I don’t really like the video.)
just like Soviet tanks during the WWII.
And the top of the tank turret matches this perfectly.
But part C3 is smooth! So, squirm as you like!
  1. I also drilled the barrel of an anti-aircraft machine gun - a habit.
  1. I was not able to assemble the knot in step 16 in such a way as to maintain mobility.
Then I had to carefully break it down and simply insert the C9 part into the C4. They fit snugly enough into each other and now hold without gluing.
  1. Also, according to tradition, I first glued the mask of the gun, and only then began to glue all the small things on the turret.
  1. My heart sank as I looked at the opaque windows of the commander’s cupola.
I even wanted to choose with a drill, but then changed my mind, afraid of the difficulties and the risk of damage.
There are two lines of T29 tank models: Takom and HobbyBoss. In such cases, I, and most likely everyone, is tormented by the question: “Have I taken the best set?” What is interesting when getting married, such a question does not arise at all, but you clearly have not familiarized yourself with the entire model range.
I could not find a store that had both Takom and HobbyBoss models in stock at once, but on average, models from the first manufacturer cost almost one and a half to two times more.
I hope this material will help you in choosing a particular model.
In my analysis, I will rely on the experience of assembling the model from HobbyBoss and on the review of the model from Takom on the website moxingfans.
As practice shows, within the same model line, manufacturers adhere to the same principles and transfer a significant part of the plastic from set to set.
I will not compare the quality of the plastic, the fit of parts, historical accuracy, etc., this is only a conceptual comparison.
1. Takom has a slightly richer underside.
2. Caterpillars are semi-set
But full of traces from the pushers (this is not about drugs)ю.
As a cherry on the cake: on the Takom 2064 model
Tank tracks are assembled on a special conductor
With its help, the axles of the rollers are aligned
3. The top of the hull is given in two halves, while the entire engine plate is given in one detail.
grills turn out the same miserable.
4. Fenders are given as separate parts.
There is a cable and it is metal.
5. The gun mask can be assembled in two versions.
6. The lower part of the turret has the same texture as the upper.
7. The most important thing is that there are transparent parts!
Photo from the review “T29E3 U.S. Heavy Tank”.
8. There is no need to even talk about comparing decals.
9. There are casting numbers on the tower.
10. The “back of the head” of the turret is given as a separate detail.
11. And on trifles: a movable course machine gun, fuel tank necks are given as separate details, unnecessary attention was also paid to the inner sides of hatches, an interesting set of camouflage schemes, and a more elegant headlight guard.
The starting position for T29 is this: the model is assembled and everything is primed.
I plan to paint using a set from AK interactive and with a set of 6 colors, or rather shades, to achieve the effect of shading / lightening. However, you will see for yourself, because. I will try to keep you informed of events that will unfold slowly, because a grandson has been transferred for the holidays and this factor does not contribute to the collection of models.
Someone please tell me (or give a link) to the technology of painting the tracks of American tanks. For the Soviet ones, I have a solution, but it does not really fit the American ones.
I am a Volunteer/Docent at the US Army Armor & Cavalry Collection. We have one of all the T-29 series, et al. LMK if you need particular photos: I will be there 2 November.
For steel tracks, the locale and season can dictate. Rusty/stains, earth and muck. Steel track shoes will usually burnish a bit, so the steel chevrons are polished with a 2H lead along their length. I’ve seen Ammo Brand oil brushes used to stain the track and boogies, and HVSS/VVSS. I used Vallejo pigments for depth and definition.
Experiment and have fun
