3D printed 1/35 Delta Force figures
I got these 3D printed 1/35 figures a few weeks ago. They were advertised as Delta Force. They are hollow and very fragile. Some parts like the antennas on the radios all snapped off and went missing. They did not include the scopes or any other peripherals. I added Live Resin scopes and laser designators.
This is how the figures arrived. They were glued to the inside of the plastic container. The figures were glued solidly to the plastic container and would not come loose. I had to cut away the container to remove the figures.
I also got the gray ones as 3D printed as well and they are slightly shorter than the brown ones. The gray ones are solid and are more sturdy. Some of the gray figures were exactly the same pose as the brown ones so I have a couple duplicates of the same figures. The radio antennas are all still attached on the gray figures. Some details are missing on the brown ones like the mic and the chin straps. They did not break off, they were never printed. The two on the left, you can see the chin straps and mic on the gray one but the brown one is missing those details. The gray one also had a warped rifle but a few seconds in hot water fixed it.
Here you can see the chin straps and mic were never printed. Also, the gun barrel was broken and still attached to the stems.
Hopefully you didn’t pay too much for them. The files for all of them can be found for a couple bucks each (some free) on Cults3D. I think I have a few of them. My guess is the guy who did the tan ones hollowed them out to save on resin. It does make them more fragile and smaller items will not print correctly.
I don’t have a 3D printer but I got them off Aliexpress for a lot cheaper than they are on Ebay.
Got quite a few of the figures primed the other day. I used Krylon spray can primer. Most will get camo decals but some of the tank crew figures (USMC) will get airbrushed solid colors.
Got them gloss coated today. The small areas on the boots not primed is where the clips were holding the figures when I primed them. The boots will be hand painted anyway.
Also got 3 more primed and gloss coated today. I used gray primer instead this time.
