Hello, I’m nearly done with the bear of meng special edition T90A, the only detail left is the bloody mouth, I did the blood around the nose but I have no idea how I should do the mouth inside and the teeths, drybrush blood?
The figure on the boxart:
The inspiration for the nose:
I’ve not painted a bear before but I guess I would tackle it in a similar way to any other mouth. Paint it the correct flesh colors and the teeth- then add whatever color you are using for blood. But add it in a wash so it sits into all the recesses and corners of the mouth and around the teeth. Then, for more dried blood, I would drybrush a little around the teeth to suggest how the blood has stained them.
I’d paint it with a salmon color with a mid-light flesh. Teeth an beige sand color with off-white highlights and for blood I’d run a red wash around it. That’s what I do with my 28mm predators.
