Looking for a quality acrylic primer red.
Thanks,
Dan
I like Ammo One shot primer, although they do not have a red but brown oxide, and the same for Vallejo and AK (their reds are too reddish)… I would use their grey primer and then my favourite red paint over it.
If you’re looking for a German Red Primer paint color, you could try AK or AMMO, or Scale 75 Warfront. Pretty much every paint company makes a German Red Primer paint or set. AMMO makes a modulation set.
Thanks, I mixed up some Tamiya flat red and added Tamiya hull red to get a shade that I liked.
I’m also tried Mission Models primer red and found that real easy to use.
I used to use Tamiya’s Fine Line Primer in Red Oxide for my German tanks; but now is hard to find and expensive. I have a can or Mr. Hobby’s Mr. Finisher Red Oxide primer; see how that works out.
I’ve got both those cans but I wanted to use my airbrush to get in tight areas.
Vallejo has it as does Mission Model.
I can give the Mission a big thumbs up as it went down nicely and required no thinning and had no smell.
No smell!
