Well this is my first attempt at building for a number of years, due to medical. I was wondering if there are pitfalls with the kit? Just wondering. Thanks as always
Is it the basic version? I built the /4 variant but other than the cargo arrangement they should be the same I think.
Reported issues (based on community builds)
1) Tricky fit in the rear compartment
There are reports of interference between the inner side panels and the rear seats:
- Rear seats can be slightly too wide for the available space
- Some builders had to sand, thin down, or even trim parts to make them fit (KitMaker forums)
Practical tip:
- Dry-fit is essential before painting the interior
- It may help to partially assemble the hull first and then adapt the seats to the available space
2) Slightly oversized rear panels
A recurring comment:
- Some panels (especially in the rear area) appear to be slightly oversized (KitMaker forums)
Effect:
- Can create gaps or stress in the assembly
- May push the structure out of alignment
Typical fix:
- Sand inner edges as needed
- Test-fit using tape before committing to glue
3) Front suspension alignment issues
Specific reports mention the following:
- Suspension mounting points donât always line up well with the locating holes (KitMaker forums)
- Even enlarging the holes doesnât always fully solve the issue
Risk:
- Incorrect geometry affecting wheel alignment and track fit
Experienced builder tip:
- Dry-fit everything and use a flat surface or jig to ensure proper alignment
4) Sprocket and tracks assembly challenges
Reported issues include:
- Difficulty closing the sprocket correctly
- Needing to force-fit parts to accommodate the tracks (KitMaker forums)
Implication:
- Can compromise track tension and final look
Recommended approach:
- Test-fit sprocket and tracks together before final assembly
- Adjust diameter slightly with careful sanding if needed
5) Typical AFV Club engineering traits
General observations across builds:
- Instructions can be unclear
- Limited locating pins
- Constant need for:
- Dry-fitting
- Cleaning up contact points
- Thin parts and tight tolerances
In short:
This is not a âshake & bakeâ kit like Tamiya â it requires a more hands-on approach (KitMaker forums)
6) Sensitivity to build sequence
Important note from builders:
- Small mistakes early on can snowball later in the build (KitMaker forums)
Typical scenario in this kit:
- If chassis or suspension alignment is slightly off:
- The hull may not close properly
- Tracks wonât sit correctly
Overall community assessment
Cons:
- Tricky fit in rear compartment
- Slightly oversized rear panels
- Front suspension alignment issues
- Sprocket and track assembly can be challenging
- Unclear instructions and limited locating aids
- High sensitivity to build sequence
Pros:
- Good level of detail for its age
- Accurate overall shape and proportions
- Realistic individual-link tracks
- Versatile subject for dioramas and conversions
- Excellent final result if handled carefully
Honest summary:
A âmodellerâs kitâ â rewarding if you take your time, but unforgiving if rushed.
Really useful summary of possible issues as well as the pros and cons of the kit! Thanks!
I had swapped the positive and negative points.
Yep, Iâm looking at my one in the display case as I type this. I remember really struggling with the back part. But when done it looks OK. I donât think they could have done a test build before releasing it.
Good to hear youâre getting back into the hobby after issues. Not sure your experience before hand but a AFV Club would not be the recommendation for knocking the dust off. Either way post your progress.
Thanks for the input. I think Iâll go with the Dragon version, besides I havenât had much luck with AFV Club
Do Dragon do one? I donât remember it. They do an Sdkfz10, with and without gun to tow, or with and without crew, which is totally different vehicle, the 10 is the 1 tonne vehicle (basis of the Sdkfz250), the 11 is the 3 tonner (basis for the Sdkfz251). The Sdkfz 10 was subsequently upgraded so it could tow the Pak40 and the LFh 18/40, which both weighed 1.5 tonnes IIRC, which removed the need for the larger vehicle.
