AGM-12 and AGM-45 with or without A-4E
I’ve wanted a Skyhawk for a while and finally found the variant I want. It is the Hasegawa A-4E. Trouble is, I realized it doesn’t have any weapons. I wanted to do it in this configuration
With AGM-12C bull pup on the inboard pylons and AGM-45 Shrike on the outboard ones. Does anyone have some of these in there spares they would want to sell? I don’t want to buy the entire weapons set from hasegawa as all my other modern jet kits have plenty of weapons
Alternatively I would also take the A-4E and weapons off someone as a package
Some good options.
https://www.scalemates.com/kits/reskit-rs48-0429-agm-12c-bullpup-b-missiles-2-pcs--1531502
https://www.scalemates.com/kits/reskit-rs48-0451-agm-45-shrike-missiles-with-lau-34-launcher-2-pcs--1514197
Hasegawa makes A-4E kits in 1/72, 1/48, and 1/32. Which kit do you have?
Ah my bad! Knew I left something out. Would by he 1/48 one!
I believe you need the data link pod for the Bullpups too,
On some aircraft types such as the FJ-4 Fury in the photo above. Other later types had the data link equipment built into the airframe. The A-4 being one of those types with the equipment carried internally.
Bump up
No longer needed, decided to go with rockeyes on hasegawa weapons set A and resin Zuni rockets
