The air valve (trigger valve) can be disassembled and cleaned. Use a cellulose (lacquer) thinner. Use a very sparing amount of airbrush lubricant when reassembling. (You can also use lip balm around the threads as a sealant.) The parts diagram shows how the thing comes apart. The threads are very fine, and the knurling is subject to gouging with pliers. You don’t need to put the gorilla grip to any of the parts when reassembling.
If you bung up the surface with pliers, as long as it will reassemble, the surface damage won’t affect the operation. So, don’t sweat nicks and scratches on the outside.
(If you can build models, you can take one of these apart and put it back together again.)
Often as not, you can remove the entire valve assembly and soak it in lacquer thinner. Work the valve with the trigger stem until it moves freely. Dry out and work a small about of airbrush lube down into it using the trigger stem to work the moving parts. If the obstruction wasn’t too bad, this will usually get things working OK again.
Usually, the most common cause of sticking in the air valve is paint. Be careful with any paint that is spilled on the outside of the airbrush. If it starts to run into the trigger or down into the body, stop and wipe it off. (You can do a detail clean later, just don’t let wet paint run into any area behind the paint cup.) Also, be careful when cleaning the paint bowl and needle that you don’t back-flush thinned paint or dirty thinner / cleaner back into the airbrush body with the needle removed.
With the O-rings (part 50-046), the trick to keeping it serviceable is to always remove the needle for cleaning by pulling from the rear of the handle. Don’t push the needle out of the front of the airbrush. In operation, an annular ring of dried paint will build up on the needle behind the O-ring. This is normally OK, since when the needle is fully forward to close the paint tip, this ring of paint just rests behind the O-ring. However, if you remove the needle by pushing it out the front (through the air and paint tip area), this ring of dried paint works like a rasp as it is forced through the O-ring. Not good. So, pull the needle out of the rear of the handle. Clean it. The reinstall forward back through the handle.
Apply a sparing amount of airbrush lube to the shaft of the needle to the rear of the taper. This is the part of the needle that passes through the O-ring and also through the stem of the trigger. Bot of these are wear points (and the O-ring seals paint from entering the handle and getting into the air valve). You don’t need lubrication on the tapered portion of the needle where it passes through the paint cup and into the paint tip.
