Hello. I am finishing an M978 Hemmt and I don’t know where the antenna base is installed. Thank you very much
Hi,
There are a lot of photos here, though not all available at the same time (it differs through a month)
Regards
Thomas
On A2 HEMTTs, if they carry a radio, the antenna is usually mounted on the back plate of the spare tire mount.
Not the best pic, but you can see it here:
Thank you both very much. I understand that in the initial version the antenna base is in the same place as in later versions.
All the best
