I was wondering if the AS-90 used the same tracks as the Leopard 1?
Bronco do a set AS90 SPG Workable Track Link Set, Bronco AB3524 (2009)
The early Leopard 1 had Diehl D139E2 tracks.
The later ones had Diehl 640 A tracks. This is the type that resembles the AS 90 's.
Whilst supposedly the same track link type the Bronco set does not fit Takom’s Gepard’s sprocket.
How many links/side should i be using for the tracks?
Right side 86 with the track a bit tensioned.
For the other side 85.
But it also depends on how you assemble the suspension, so you might end up with one more or less
