Something the detailing modeller?
this is the M60/AVLB version and not the M88 correct?
Do you want photos of the M88 engine?
no just wondering if I still have my mojo in being able to ID stuff
Is this the out put shaft for the engine? Sure looks to be a fairly small diameter for such a big engine.
Cajun ![]()
No, that is a PTO/accessory drive. The whole unit is the engine and the transaxle (red rectangle, aluminum / dirty light metal color), at the rear. The main outputs are at each side of the transmission where the prop shafts (drive shafts) attach, circled in blue.
Thanks for clearing that up Gino, I was bewildered by that tiny shaft.
Cajun ![]()
