jmarc
10 June 2024 21:39
1
jmarc
10 June 2024 21:40
3
Thanks for following the WIP on this project , it’s quite appreciated !, here the latest update
(JUN 10th ) Today , glued the rudder section to the tail cone and sanded the forward section !
If you like to view the complete WIP on this project , just follow this Google link :
Enjoy and it’s an ‘rendez-vous’ next week for more on this particular project…!.
Jmarc
jmarc
17 June 2024 21:02
4
(JUN 17th ) Today , sanded the work done last week, , sanded the next section and started engraving it !
Jmarc
jmarc
26 June 2024 21:32
5
(JUN 25th ) Today , sanded the work done last week , continue engraving it and finally add some more putty !
Jmarc
jmarc
8 July 2024 20:54
6
(JUL 08th ) Today , sanded the work done last week , done the last panel engraving , glued the section to the tail and add some putty !
Jmarc
jmarc
15 July 2024 20:48
7
(JUL15th ) Today , sanded the work done last week , apply more putty and start panel engraving on the next fuselage section !
Jmarc
jmarc
22 July 2024 21:14
8
jmarc
29 July 2024 21:01
9
(JUL 29th ) Today , sanded the work done last week and add more putty , continue engraving the panel lines on the mid fuselage section !
Jmarc
jmarc
12 August 2024 21:39
10
(AUG 12th ) Today , sanded the work done last week and add more putty , continue engraving the panel lines on the mid fuselage section !
Jmarc
jmarc
19 August 2024 17:46
11
(AUG 19th ) Today , sanded the work done last week and add more putty , I engrave the side access doors !
Jmarc
jmarc
28 August 2024 11:21
12
(AUG 27th ) Today , sanded the work done last week and gave it a coat of paint ,and engrave the other side access doors !
Jmarc
jmarc
2 September 2024 16:25
13
(SEPT 02nd ) Today , apply some putty to the problem area of the tail section and started to cut the inner flap from the mid fuselage section !
Jmarc
jmarc
18 September 2024 20:07
14
(SEPT 17th ) Today , sanded the work done last week and gave it another coat of primeur , continue cutting the inner flap section and started ingraving the mid fuselage section !
Jmarc
jmarc
23 September 2024 21:03
15
(SEPT 23nd ) Today , sanded the tail section and apply some more putty to the problem area , I completed the mid section panel lines and started to cut the front windshield
Jmarc
jmarc
7 October 2024 15:27
16
(OCT 07th ) Today , cut out the front windshield and started the work on the side entry door !
Jmarc
jmarc
15 October 2024 17:41
17
(OCT 15th ) Today , cut the nose section so I can do the cockpit and started to thin the fuselage sides !
Jmarc
jmarc
21 October 2024 19:07
18
(OCT 21st ) Today , I cut out the cockpit back wall and started the repair of the top winshield frame !
Jmarc
jmarc
28 October 2024 19:30
19
(OCT 28th ) Today , I work on the separation wall and done the floor !
Jmarc
jmarc
11 November 2024 21:56
20
(NOV 11th ) Today , I continue the work into the cockpit !
If you like to view what I have completed so far on the AVRO CANADA project , I have set up an GOOGLE page for them , here the link:
Jmarc
