Back to the bench
So after a year away I am finally able to get back to the bench. I got a new light and happened to pick up a good old Revell M60A3 at a garage sale. So I am starting out with just construction, gluing, sanding and painting. I have a Panda M1 that is in the finishing stages, but will come back to that after I get back into the flow. I still share the space with my son, but he is now back at college, so I can reclaim part of the room. (Having issues uploading a photo)
So uploading a picture from my iPad just seems to not be possible.
Are you trying to upload it from the cloud?
In the toolbar above where you type your message, tap this button: Upload
A menu will appear in which you can choose to upload a photo from your library, a file or take a photo. When you chose one (or up to five at a time) from your library, tap the options button at the bottom and choose to upload them in large size, not full size — the forum often chokes on them if you use full size, is my experience, but large is plenty big anyway.
Been trying that, and all different file sizes. No luck.
OK, then the question is: how doesn’t it work?
For example: Does it keep saying underneath the message that it’s uploading the photo, but that remains stuck on 0%? This happens on my Mac, and it’s caused by a recent update to the forum: apparently, my version of Safari is too old, because uploading works fine on my iPad with up-to-date iPadOS, and also in Firefox on my Mac. If your iPad runs a version of iPadOS of some years ago, it might be you’re running into this same problem.
That is what happens, just the spinning wheel stuck at 0%. My iPad is older so that may be the issue.
Try installing Firefox on your iPad, to see if uploading photos works in that.
