Dont you just hate it when you have one of those bad airbrush days where nothing works?
I had one today. Trying to airbrush semi hard edge camo stripes on a Tiger. Base coat of dunkelgelb(s) went down like a dream. Camo just… appalling.
PS771, 0.15mm needle with the limiter dialed back. VMA Dark camo green, well shaken, a drop of drying retarder and 25% thinner. Dropped the pressure to 12% - spiderweb city. So I must have over-thinned it right?
Emptied the brush, cleaned it and tried again only without the thinner. Immediately dried on the tip. Cleaned the brush again. Tried again, spiderwebs - it was going down way, way too wet. Also spattering.
Figured the brush must need a deep clean and it might have been a nozzle issue.
Changed the brush to Takumi Custom Micron, 0.15mm needle. Exactly the same. Not getting nice fine lines as I should do.
So I figure I need to increase the pressure a little as the spattering is the paint not atomising as it should as I’m in too close, so i need to increase the pressure. Tried it at 20, same result. Tried it at 22, the air just chases the spatters all over the model.
Maybe the Takumi needs deep cleaning?
Pulled out my reserve Fenga FS180 with a 0.20mm needle and tried that - worse because the back stop doesnt have enough control to work effectively for the fine lines.
I deep cleaned all my brushes, emptied the paints, emptied the moisture trap on the compressor and started again.
12psi pressure, 0.15mm needle, PS771 detail optimised airbrush. Same paint, different bottle in case it was the paint.
Still not happening. Overspray all over the place, tip drying every few seconds, spattering, going down way too wet, inconsistent flow, either none or flooding, and then working fine for a few seconds, then going haywire again.
So annoying.
Anyone else have those days too?
