So as i started to work on the Amodel C-8 i realised how easy that project looks, so i decided to start the Beriev Be-6 aswell. Will be interesting to do two builds at the same time.
I started with the fuselage, this one look actualy easier than the C-8. THe fuselage is in two parts only and the fit is better. Also there are no windows.
Will be following Jacob, should be interesting
Made som progress on this. Im keeping it simple, because the kit is realy small and its just a sideproject right now. Fit is not great and a lot of putty wss used so far. Panel lines are fine but are missing on some parts.
I need to clear out the workbench, so Im pushing the Beriev as fast as possible. Decals were very bad on this kit and I used only the yellow numbers. All the stars are from an MA set.
Excellent work jacob. Like the paintwork
A dash to the finish. I know the model has probably a hundred things that could be done better, the colours I chose for one can probably be discussed (more greish and less blueish). But this is as much time I can invest right now. And one of the reasons is on the last picture - the bigger brother Beriev Be-12 in 1/72 which is also a much complex and frankly better kit.
Looks pretty damned good from the images Jacob, nice job
Amazing work in that scale. A beautiful looking model.
