Best Method to Accelerate Paint Curing?
Anyone tried an adjustable temperature food dehydrator?
Thanks
Thanks
I think a recent example illustrates why we should let the paint do its thing on its own.
I wouldn’t go any further than a fan at low RPM’s blowing room temperature air on the model.
I agree biggles
For figures I sometimes use a hairdryer- particularly for glazes. I would also use it the odd time if I’m putting oils on a vehicle. Never tried it, say, to get primer to dry quicker but with a low setting it might work well.
Time. That is all. Accelerating curing time or not waiting long enough will result in the paint cracking/crazing, ruining your finish and your model. Don’t mess with base paint curing.
Flame thrower.
Getting a job - that worked for me like a charm! Paint something, get some sleep, go to work - you come back and the paint is perfectly dry!
Much later I found that the Citadel paints dry insanely fast in comparison to Humbrol Enamels I was using before.
Hope it helps - good luck with your projects and have a nice day
Paweł
Switch to water based acrylics, as Pawel states they dry really fast.
A word of caution - drying and curing are two different things.
Appreciate the suggestions.
Airbrushing water based acrylics aren’t to my liking at all due to religious reasons. It is written in the Book of Armaments, #7 Commandment Thou shall paint with enamels, lacquers or lacquer-acrylics.
Assuming someone was “pig headed” and determined to proceed experimenting with a food dehydrator, what temperature would you favor between 95F/35C and 180F/83C ?
Thanks again
There are a number of videos from the miniature painting community that have been presented, such as the KEENSTAR dehydrator from Amazon. One of the YouTube presenters, Barbatos Rex, has a video comparing that one against the one he uses to cure paint after airbrushing. In that video, he mentions that he normally has his set to 120°F.
DEFINITELY the lower setting.
Baking styrene above 50 Centigrade can lead to unwanted deformations, no bueno …
(Pretend this is Thyme)
Patience.
A fellow modeller regularly used one to accelerate the curing of his resin castings, I guess it should be ok for painting as well
