Progressing slowly but surely
One half of the tracks done and most of the tank build. Leaving the hatches of until I decide if I should add a crew.
More to follow
More to follow
Hi Jesper, that’s a real beast you’re building! How were the tracks? They look fiddly if you had to pin each link…
They are fiddly, But luckily do not have to be pinned. There are some parts that click in place and a big connecter link in the middle.
The time consuming part is mostly cutting out the parts….
Still a beautiful piece of track when done.
Right, it’s been too quiet here for too long! I finally found time to do some work on my DIVAD runner-up, cutting a turret frame from 0.060" sheet and adding slabs around the sides as a shell. Then I built the gun based around a rod pivot, and surprisingly it came out OK. (Fortunately the drawings show a hatch on the right side just where I needed access to insert the pivot…)
Still need to think about the radar units, but it’s getting there!
Loving that Tom.
Beautiful scratch building!
Another update - I finished the turret! The cupola comes from an M113 kit since it seems reasonable to assume they’d use something already in production and the sketches are vague. The radars are the big issue - I built them as best I could from scraps and a section of the water tank in an Italeri truck. They are “good enough” and I couldn’t find anything better to base them on!
Now it just needs some paint…
Loving this Tom. Great work.
Trips and illnesses after them somewhat stopped my activities. I present a brilliant (lacquer) result of my work. It would be better if it would be a brilliant work, but okay.
That’s looking pretty good to me! Those heavy prototypes were massive beasts, even at 1:35 scale.
The production version. M34 Heavy Tank. A Company, 746th Tank Battalion(Heavy), 3d Army. Germany. 1948. Steroscopic range finder from T-29E3, 810 hp Continental engine from the T-30/34. 120mm gun from T-34. And 18 inch Crouse & Hinds searchlight. Last photo is with an M4A3E2 (76) for size comparison.
1/35 Polish PL-01 Light Tank. 24 Pulk Ulanów,10 Brygada Kawalerii Pancernej, 11 Lubuska Dywizja Kawalerii Pancernej, Wojska Lądowe. (24th Ulan Regt., 10th Armored Cavalry Brigade, 11th Armored Division, Polish Land Forces.)
Panther-san. The Type 4 medium tank, Chi-To. Armor …12–75 millimetres (0.47–2.95 in)|
Main armament …Type 5 75 mm tank gun … Type5,_75 mm_tank_gun (L/56.4)
Secondary armament …2 × Type 97 heavy tank machine guns.
Engine … Mitsubishi AL Type 4 37.7 litre air-cooled V12 diesel engine with supercharger.
400 hp at 2,000 rpm.
Operational Range … 250 km(160 miles).
Maximum speed 45 kilometres per hour (28 mph).
As far as I know one was finished, combat capable on VJ-Day. A second partially finished. Ability was suppose to be on a level between a Pzkw IV and Panther.
Some more progress on my Maus. I used the vallejo modulation system. First time I used this system. Pretty satisfied with the first try.
More to follow
Just catching up after a week’s sojourn in Malta - damn fine work Tom, damn fine. 'Looking forward to the paintjob!
That’s some impressive drilling!
