Yep, they were all the rage for new houses in NZ in the late 70ās & 80ās, but donāt often see them nowadays
Mal
Well that was some useless information I wonāt forget! ![]()
Clinker comes from Dutch klinker, literally āsounderā, due to the clear sound they make when hitting one with another ā like he also explained just when I was typing that bit
Generally, these days, it means a brick used for paving rather than for constructing buildings.
But the irregular shape part is dubious, IMHO, unless thatās a specific American meaning attached to the word, since over here, klinker is used to refer to perfectly-shaped bricks as well.
I hate it when that happens to me
In Sweden ākilnkerā means a tougher ceramic tile to be used on floors.
Klinker is ceramics based on stone, the other tiles are based on clay
and fired at a lower temperature
Are you hinting at a future diorama?
Edro
No farking way
I donāt build dioramas and I donāt do figures.
I only bother with interiors if there are no hatches to close.
I donāt open truck doors. Steering wheels are going straight.
I have problems getting time and opportunity to build anything.
I have seen too many brick walls laid out in LEGO-style and I have
posted about the various bond types and how bricks would be laid.
If someone is doing a diorama they might as well get the bricks
right, just as important as fussing about the correct weld pattern
for a Sherman tank built by a particular factory.
Iām with you there, brother.
Edro
Several garden walls are built with these in my north London road. They were the āwasteā material left over where small-scale local brickworks were established as suburban London expanded rapidly in the Victorian era and subsequently
Welcome to the forums Ken!
Cheers /
Your (mostly
) friendly local moderator
Robin
