This is an older Zvezda kit, a reboxing of a mold from Dragon. It was a bit of a challenge, the suspension instructions weren’t very clear and it took a bit of trial and error to get it right. There was a bad injection error in the lower chassis. It isn’t visible from the outside, but if you look inside the rear, left side wheel, there is a big section that is open space where the styrene didn’t fill the mold. Fortunately with the tire on it isn’t visible unless you pick it up and look at it.
No where near one of the best kits I have built. But not the worst either. Did it in UN white and usually that adds a lot of depth to a build. Just some mild dirt effects for weathering.
