Building the Koksan M1978 in 1/35 Scale
Building the Koksan: Can We Get It Right?
Part 1 — Research, References & Gathering the Parts
Some modelling projects make you want to start building the moment you see a photograph. Others make you stop and think: this is going to be complicated. Perhaps even ridiculously complicated.
And somehow, that only makes them more interesting.
For me, the North Korean M1978 Koksan is one of those machines.
Imagine a tank chassis carrying an enormous 170 mm gun. An exceptionally long barrel, an exposed artillery mounting, massive rear spades, and proportions that almost seem impossible. At first glance, it looks like something straight out of an alternate-history concept.
Except it isn’t.
This vehicle actually existed, entered production, and saw combat.
And now I want to build one in 1/35 scale.
Not just something that looks vaguely like a Koksan, but a model with convincing proportions, accurate details, and construction features supported by photographs of the real vehicle.
This is my first build log on KitMaker Network. Rather than showing only the finished result, I’d like to document the entire journey: research, component selection, 3D printing, test fitting, mistakes, modifications, and those small technical victories that make projects like this worthwhile.
Hopefully, some of what I discover will help other modellers build their own Koksan without having to repeat every mistake I make along the way.
Or perhaps we’ll uncover a few questions that nobody has convincingly answered yet.
Either way, I don’t think this project will be boring.
1. A Vehicle We Know Surprisingly Little About
170 Millimetres of North Korean Engineering
The M1978 Koksan is a North Korean self-propelled artillery system armed with a 170 mm gun.
The M1978 designation was assigned by Western analysts, referring to the year the system first became known outside North Korea. The name Koksan is associated with a North Korean geographical location and has become widely established in Western publications.
The vehicle uses a heavily modified tank chassis, generally associated with the Soviet T-54 family and the Chinese Type 59. Its enormous gun is mounted in the open, without a fully enclosed armoured superstructure, while two massive rear spades help absorb the forces generated during firing.
Koksans were supplied to Iran and used during the Iran–Iraq War. Some examples subsequently ended up in Iraq, leaving us with photographs of vehicles that would otherwise be extremely difficult to study.
Those photographs are particularly valuable to scale modellers today.
But the deeper I went into the subject, the more obvious the problem became: there are far fewer useful references than it initially appears.
The same photographs are reproduced across dozens of websites. Some images are available only at low resolution. Certain drawings have no identifiable source, while technical descriptions occasionally contradict one another.
And building an accurate model requires considerably more than knowing the vehicle’s overall length and gun calibre.
I want to understand how the gun mounting is constructed, where the weld seams run, how the fuel tanks are attached, which running gear components were retained from the original tank, and exactly what changed when the Type 59 was transformed into an artillery chassis.
So I decided to begin with research rather than printing.
Piecing Together the Evidence
My reference archive gradually developed around several groups of sources.
One of the most useful was Joseph S. Bermudez Jr.'s research on North Korean M1978 and M1989 artillery systems, published in KPA Journal.
I also consulted US military publications, particularly the Worldwide Equipment Guide, along with available photographs of surviving vehicles.
Special attention went to Iranian examples, historical photographs from the Iran–Iraq War, and images of a captured Koksan photographed by US Marines in Iraq in 2008.
The latter series is especially interesting because some photographs reveal details that are almost impossible to identify in parade images.
Another major part of the research concerns the Chinese Type 59.
Although the Type 59 was derived from the Soviet T-54A, assuming that every component is identical to its Soviet counterpart would be a mistake. Differences may involve weld seams, external equipment, production details, and subsequent modifications.
And the Koksan is certainly not just a tank with its turret removed and a large gun installed.
Its hull and overall layout were extensively modified.
This means photographs of a standard Type 59 are useful for understanding the original construction, but the M1978 itself must remain the primary reference.
I also purchased AMMO by Mig Jimenez’s T-54 / Type 59 Visual Modeler’s Guide to help study the hull, running gear, and characteristic details of the vehicle family.
One important limitation is worth mentioning: I still haven’t found a complete set of reliable factory drawings for the M1978.
Some dimensions and construction features will therefore have to be reconstructed by comparing photographs, known measurements, and components of the original tank chassis.
It isn’t a perfect method, but at least it allows me to test assumptions systematically instead of relying entirely on someone else’s interpretation.
A Little Field Research
I also decided to take the research beyond books and online archives. I visited a military museum with both T-54 and T-55 tanks on display and put together a small photographic reference collection, focusing on details that are often overlooked in general walkaround galleries: weld seams, mounting brackets, surface textures, and other small construction features.
Of course, neither vehicle is a direct substitute for the Chinese Type 59, let alone the heavily modified Koksan chassis. But examining real vehicles up close provides a useful additional perspective.
My next step will be to compare these photographs with the material in AMMO by Mig Jimenez’s T-54 / Type 59 Visual Modeler’s Guide, looking for similarities, differences, and details that might help with the build.
I’m not drawing any conclusions from this comparison just yet. For now, it’s another piece of the reference puzzle.
2. Buy a Digital Model or Spend Months in CAD?
This is where things start getting interesting.
Initially, I considered developing the entire vehicle myself in 3D.
It’s a perfectly realistic approach: gather references, reconstruct the geometry, create the CAD model, divide it into printable components, design locating features, and go through several rounds of testing.
There’s just one problem.
I also have a full-time job, and the prospect of spending weeks, possibly months, developing the digital model before even touching a physical component wasn’t particularly appealing.
I wanted to start building something.
So I decided to run a little experiment and purchased the M-1978 Koksan / Chuch’e p’o from Dent, by Design.
The 3D-print version is listed at £60.
This isn’t simply a visual 3D model intended for rendering. The manufacturer offers a second revision specifically prepared for producing physical parts.
According to the product description, the package includes 72 individual STL components, a digital booklet, and materials for producing decals and photo-etched parts.
The manufacturer also states that the kit is intended for experienced modellers and may require adjustments depending on the printer, resin, and printing conditions.
And that’s a perfectly reasonable warning.
Anyone familiar with resin printing knows that having an STL file doesn’t automatically guarantee a perfect physical part.
You have to consider orientation, support placement, resin drainage from hollow sections, material shrinkage, potential deformation of long components, and dimensional accuracy after washing and final curing.
Especially when dealing with a large artillery installation containing long, relatively thin, and structurally demanding parts.
But I’m interested in more than print quality.
The bigger question is this:
How accurately does this digital model represent the real M1978, and can it serve as the foundation for a genuinely convincing scale replica?
I don’t have the answer yet.
And I’d rather not draw conclusions before doing the work.
Why I Didn’t Print the Chassis
The purchased model includes a complete chassis.
In theory, I could have printed the entire vehicle and assembled it as a full resin kit.
Instead, I decided to try something different.
I purchased the HobbyBoss PLA 59 Medium Tank — Early, in 1/35 scale, to serve as the foundation.
This doesn’t mean I consider the printed chassis inferior. I haven’t even carried out a proper comparison of their geometry yet.
I’m simply interested in exploring a different approach: combining a conventional injection-moulded plastic kit with a 3D-printed artillery installation and aftermarket components from several manufacturers.
Plastic is convenient for cutting, drilling, modifying geometry, installing internal reinforcements, and repeated test fitting. For a substantial conversion project, those advantages may prove useful.
This approach will also allow me to evaluate how well the digital artillery installation fits the geometry of an existing plastic kit.
In other words, I’ve deliberately made the project a little more complicated.
But that’s exactly what I want to investigate.
3. Some Plastic, Some Resin, and Plenty of Questions
Once I’d chosen the foundation, I started gathering aftermarket parts.
There’s one important point I’d like to make here.
I wasn’t trying to create the ultimate shopping list for building a Koksan.
I don’t have one yet.
Instead, I selected several components that might prove useful, and I want to test their compatibility, quality, and historical suitability.
What’s on the Workbench?
HobbyBoss — PLA 59 Medium Tank (Early), 1/35
The injection-moulded kit that will form the basis of the chassis.
T-Rex Studio TR85045 — Type 59/69 Tracks
A set of 195 individually 3D-printed track links. According to the manufacturer, they can be assembled as workable tracks without glue.
I’m particularly interested in examining the link geometry, the fit around the drive sprockets, and how convincingly the details reproduce the real track design.
For me, tracks are one of those components that can make a remarkable difference to the overall appearance of an armoured vehicle model.
ET Model P35-258 — Lights Set for PLA Type 59
An aftermarket lighting set designed specifically for the Chinese Type 59.
I want to examine not only the quality of the headlights and protective guards, but also whether they are appropriate for the M1978.
After all, the external equipment of a modified artillery chassis doesn’t necessarily match that of the original tank.
Legend Productions LF1219 — T-55 Fender Fuel Tank Set
A resin set of external fuel tanks originally intended for the T-55.
At this point, there are more questions than answers.
Will the dimensions work? Are the shapes and mounting arrangements correct? Will some parts need to be modified?
We’ll find out.
Voyager Model PE351032 — PLA Type 59 Main Battle Tank Basic (for Takom)
Voyager Model PE351033 — PLA Type 59 Main Battle Tank Fenders (for Takom)
These two photo-etched sets will be my primary starting point for the hull’s exterior detailing.
Although both were originally designed for Takom’s Type 59 rather than my HobbyBoss kit, they offer an interesting opportunity to experiment with the vehicle’s finer structural details, particularly the fenders and their associated components.
Of course, their compatibility with the HobbyBoss hull remains to be tested. I expect that some adjustments may be necessary, especially around mounting points and the dimensions of individual parts.
Rye Field Model RM2056 — T-55A Mod.1981 Upgrade Solution Series
I also purchased the RFM upgrade set, originally designed for the company’s RM-5098 kit.
Unlike the Voyager sets, which I intend to use as my primary reference for the exterior detailing, the RFM set was purchased mainly for comparison.
I’m particularly interested in comparing how the two manufacturers approach the fenders and other exterior components, both in terms of engineering and the level of detail.
Since these sets were designed for different kits and, in the case of RFM, a different tank variant, I don’t expect their parts to be directly interchangeable.
Whether the Voyager components prove more suitable, or whether some RFM parts offer a better solution, is something I’ll determine during the test-fitting stage.
For now, these are simply different approaches worth evaluating. I’m not drawing any conclusions about their accuracy, quality, or suitability for the Koksan until I’ve had a chance to examine them properly.
And What About That Enormous Gun?
The main components of the purchased digital model have already been printed, including parts of the artillery installation and the gun mantlet.
For the barrel, however, I chose a different solution.
I commissioned a custom-turned metal barrel based on the CAD geometry.
The 170 mm gun defines almost the entire silhouette of the Koksan, so the quality of this particular component matters a great deal to me.
A long resin-printed barrel presents several potential challenges: deformation during printing or post-processing, careful support removal, and the possibility of losing perfect straightness.
A turned metal component should eliminate some of these issues while providing a cleaner surface finish.
However, there’s an important distinction between manufacturing precision and historical accuracy.
A lathe can reproduce CAD geometry with excellent precision. But if the original digital profile is incorrect, the metal part will simply reproduce that mistake very accurately.
So the barrel’s profile, length, diameter transitions, and muzzle configuration still need to be checked against the available references.
For now, this is another component to be evaluated, not a final verdict.
4. No Recommendations. Just an Experiment — For Now.
Before moving on, I’d like to establish one principle that will apply throughout this entire series.
These articles are not intended to promote particular manufacturers, digital artists, or brands.
I’m purchasing components for my own project, testing them in practice, and documenting the results.
If the Dent, by Design model turns out to be accurate, well engineered, and enjoyable to assemble, I’ll be happy to say so and share a link for anyone interested in using it.
If I discover significant inaccuracies or components that require excessive reworking, I’ll document those findings as well.
If necessary, I’m prepared to design replacement or missing parts myself, using historical references and independent measurements. Should I develop useful original components, I’ll try to make them available for other modellers to download.
Of course, I have no intention of redistributing someone else’s digital files or slightly modified copies of their work.
This isn’t about competing with manufacturers or looking for reasons to criticise anyone.
I simply want to understand how well the available solutions work in a real modelling project.
At this stage, I’m not recommending any of the products I’ve purchased, and I don’t have grounds to discourage anyone from buying them either.
I haven’t completed the necessary testing.
Perhaps everything will fit together almost perfectly.
Perhaps I’ll end up redesigning half the vehicle.
Or perhaps combining injection-moulded plastic, resin printing, machined metal parts, and carefully selected aftermarket components will produce a result that would be difficult to achieve with any one method alone.
We’ll see.
5. Next Stop: The First Dry Fit
So, as things stand, I have almost everything I need to begin the experiment.
A plastic Type 59, a printed artillery installation, a metal barrel, workable tracks, resin accessories, and a growing archive of historical photographs and technical references.
Now it’s time to find out how well all of this actually works together.
The next stage will be a preliminary assembly, with the major components left unglued wherever possible.
First, I want to examine the geometry of the HobbyBoss chassis and compare it with the available M1978 photographs.
Then I’ll investigate the positioning of the artillery installation, its mounting height, proportions, and the relationships between the major structural components.
I’ll also pay particular attention to the running gear, fenders, fuel tanks, and external equipment.
There are several questions I want to answer along the way:
  • How accurately does the purchased 3D model reproduce the real M1978?
  • Can it be combined with the HobbyBoss plastic hull without compromising the vehicle’s proportions?
  • Which original Type 59 components are actually appropriate for the North Korean artillery chassis?
  • How useful will the aftermarket sets designed for the T-55 prove to be?
  • Which parts can be used as supplied, which require modification, and which might need to be redesigned from scratch?
I’m deliberately avoiding permanent assembly and fine detailing at this stage.
First, I need to make sure the vehicle’s fundamental geometry is right.
Otherwise, there’s a real risk of spending countless hours adding beautiful details to a model whose basic proportions were wrong from the beginning.
So there will be measurements, dry fitting, photographic comparisons, and probably quite a bit of plastic surgery and CAD work ahead.
For now, though, I’m looking at a rather unusual collection of parts from several manufacturers that should, at least in theory, eventually become a North Korean 170 mm self-propelled gun.
Will all of this turn into a genuinely good Koksan?
I don’t know yet.
But I’m very interested in finding out.
To be continued.
References & Resources
The following are some of the principal sources used during the initial research. They are a starting point rather than an exhaustive bibliography, and their technical information still requires critical evaluation.
M1978 History & Technical References
Photographs of Real Vehicles
Type 59 References
Digital Model Used in This Project
Wow. This has been my holy grail for years. What’s stopped me is the same thing - lack of enough references to do it properly.
And while I have access to a lathe and a 3D printer, my skills on Fusion 360 are not quite up to the task, although I have managed a few things.
I’m really looking forward to seeing what you can do.
If you need my Type 59 walkaround to get the small details, it’s yours for the asking.
WOW.
:astonished_face:
Ambitious plans!
:+1: :+1:
This will be interesting to follow.
:popcorn:
Thank you so much! I know exactly what you mean about the lack of references. That’s probably the biggest challenge with this project.
I’d absolutely love to see your Type 59 walkaround! Especially any close-ups of the hull, suspension, welds and smaller details. That would be incredibly helpful.
I’m also planning to share the most useful findings and any original parts I end up developing, so hopefully this project will make things a little easier for anyone wanting to build their own Koksan.
Really appreciate your support and the offer!
Thank you! :grinning_face_with_smiling_eyes: I might have bitten off a little more than I can chew with this one, but that’s half the fun!
Really looking forward to getting everything together for the first test fit. Hopefully there will be some interesting discoveries along the way. Glad to have you following the build!
Send me your email address. You’ll get them via wetransfer.com
Talk about glutton for punishment.. wow you wear the crown today. Looks like you have your hands full for a long winter build season. Good luck
Have you seen this take on it? (You won’t be able to see the photos at full size unless you register, but that’s free.) I don’t think he finished it, but the main thing I remember of that thread is that we had a lengthy discussion about what and how the pulleys and cables are supposed to be for :slight_smile:
Thanks a lot, Jakko! I hadn’t come across that thread before, so I really appreciate you pointing me to it. I’ll definitely take some time to go through it. The discussion about the pulleys and cables sounds particularly interesting, and I’m sure there’s something useful I can learn from it for my own build. Thanks again! :slight_smile:
