Does anyone have a fuller pic of this type of headset - which I’m assuming is used in Spz and tanks alike?
I’m really keen to see if there was a securing band - for want of a better word - on the rear. - or did it just rest on the head as it was? I believe this type still utilised throat microphones - just visible in the photo.
Any help gratefully appreciated as I’m in the middle of converting figures - again.
Sprechsatz SEM 25 with throat mike.
HTH H.-H.
Thanks Hermann, that will do nicely I think.
Thanks again.
You are welcome my friend.
Well, I think I’m more or less on the right lines:
The Driver figure for my M48A2GA2 project. What? You didn’t know about that? Well, flushed with success (more or less!) of my USAREUR version, recently completed, I thought I’d pursue the species a bit further, with the German 105mm version:
Aaaand, ready to install in my M48A2GA2:
The beret still looks a bit shiny but that’s due to the lighting I’m afraid; now, on with the build!
Panzertruppen usually wear the black beret, as do the Panzeraufklärer.
Not in this case Hermann; my model will represent an M48A2GA2 from Jaegerbataillon 531, the crews of which wore the Jaeger beret.
You’ll have to get up early to catch out Mrs Stoddart’s little boy!
not a very good reproduction, and I see I’m a bit late
Never mind Dave - all grist to the mill!
Count me in Brian.Chair pulled up and Opera glasses close at hand.Great start.
Richard
Ah, that’s caught me out a bit Richard; I wasn’t planning on formulating an article as a project as such; after all, most constructional aspects are the same as my US version. Hmmm. I’ll have to think a bit.
OK; I’ve now initiated a bespoke thread “Bundeswehr M48A2GA2 - Revell 1/35 c.1987” God help me(!)
Hermann, just to check as I’m about to start the rest of my M48’s crew; did the SEMS set-up have any securing strap (to say, wrap around the chest) to support the control box (for want of a better description). From your pics and the others it appears not. Presumably it was just held in place by the supporting straps from the neck?
I just wanted to confirm before I start scratch-building the set-up.
Brian, I simply don´t know, I need to check the net myself. Those SEM are configurations are little before my time.
Thanks Hermann; if you can come up with something I’d be very grateful. No rush I assure you. I just want to get as right as I can.
If there’s not, then all well and good, and I assume therefore it was just suspended by the straps around the neck. Not a great problem, I just want to get it right before I start work on the 2 figures.
FYI Here is the TM of the Fahrzeug Sprechfunkanlage SEM25/35.
SEM-25 tdv 5820 045-12
