OK clever people I need some help painting the canopy on my bubble top p47. (Miniart 1/48). I’ve spent too much time masking and cursing. What’s your secret to painting the frame?
Thanks
Thanks
Bare Metal Foil works well for me . Burnish down , cut along frame/glass junction with a NEW SHARP BLADE and peel away foil from areas you want painted. Leave foil on throughout rest of finishing process including decal overcoats . Remove foil from glass areas with a wooden toothpick cut to a chisel point . Clean up adhesive residue with mineral spirits.
Spend the money on the Eduard masks - makes the model look fantastic.
What amazes me is that the likes of Miniart can make the smallest pieces in plastic and pe. So why can’t they make the canopy frame as a separate piece?
I’ve only done this once, but it worked.
I admit, I needed to put two stripes on top of each other to have it sufficiently opace. I took the note that I would put a black stripe first if i would ever do that again. But a I usually build jets I’ve never done it again.
i’ve done this several times and it works very well but i only used it on straight frame parts. don’t know how i would do curved areas.
Joe
another trick that sounds counterintuitive for a canopy with many tiny windows in a frame.
Put masking tape on both sides of a single “metal” frame, paint it by brush, let it dry and do the next one.
It spares you from having to cut out every little window
