I’m working on the Tamiya Char B. Anybody know what the gizmos mounted on the rear deck, between the exhausts are? (Red circle) SWAG is some sort of “tool” for track repair. (Fork shape at one end, angled flat pad at the other. Looks like the fork would fit in the tow bracket , pad on the ground. Moving the tank toward the pole lifting that end of the tank. ) Close? Also, the strap securing the jerry cans being secured to the exhaust… how long would that last afore it burned up?
I thought track repair also. I will probably be wrong but it will get someone to correct me and get you the correct answer which is the goal. I thought I read somewhere this morning that Germans had some type of crane on the back of the Bis. Those could be the parts for it. There is a jack in front of the exhaust on the other side of the cans that is very German and added to there Char’s.
On most pictures I 've come across I see only generic tools, like pick axe, shovel etc…
While typing this, I came across a similar post on Tracklink:
Char B1 bis, jacks. - Missing-Lynx (tapatalk.com)
There it is stated that theas ar kind of supporting beams for maintainance:
They’re called “chandelles” in French (“jack stands” in English)
Those are jacks used to raise up on side or the other for maintenance.
If you look at the hull sides you’ll see the holes/brackets they fit into.
also means candle
Indeed Robin, but I didn’t want to muddy the water
Some of the amazing stuff you learn here.
“Hang on son let me get some candles to hold up the car while we work on the tranny.”
Now I know while I lived in Canada at a very young age I was very confused with the other language we had to learn
The other word for candle is ‘bougie’ which is only a bad pronounciation away from bogie (same spelling in English and French)
Just goes to prove I don’t know Jack … stand. As for muddying the waters, Frenchy, we are in the middle of a severe drought. We’ll take any water we can get, muddy or otherwise.
You are not in a drought until near 80 year old vehicles start poking out of the bottom of your Dams
Regarding that strap holding the cans down: I wouldn’t give it 15 minutes, but that’s just me.
There’s water there. When the far end of the boat ramp is 2 miles from the water … you are in a drought. ( 2021’s 8,619 fires, loss of 2,569,009 acres (1,039,641 ha) and 3,629 structures … just in California … are good clues too.)
