Its probably a flag or flags used during gunnery (or for signaling).
If the French army is like the the US army three flags are used: Red, green and yellow.
Gino might be right. The signal flags we used were shorter and the colors were the same as the US ones (probably NATO standard). Whereas the flages were mandatory in each vehicle they were not issued by the Army so they were homemade from broom sticks and pieces of cloth. We called it “systeme D”.
Now you mention it Gino, and with Olivier’s insight, I think you are right. And it makes perfect sense given the fitting between the ammo box and the hatch is the travel mount for the .50 inch. It would also fit in as this is a picture of a vehicle deployed in Algeria in 1960 during the Algerian War, not on practice.
Thank you very much everyone. Appreciate you all took the time to look at the thread.
Don’t you have a blue flag? The Bundeswehr uses 4 flags. Blue is for all vehicles in a convoy, except the last one which shows a green flag. A yellow flag means, this vehicle has a technical defect and a towing vehicle shows the red flag when it has the defect one “on hook”. During live fire shooting a red flag means “sharp ammo on board, reading for firing” and a green flag means “everything clear”. That’s what I remember from my olive green days.
There’s a STANAG (Standing NATO Agreement) for this I believe - well, that is for convoy movement: Blue at the front (of the convoy) Green at the rear, and Yellow when you’ve broken down. This is all distinct from activity on the ranges admittedly. If movement is at night then the front headlight of the lead vehicle is coloured blue, and the last vehicle also has its headlight coloured green. Not sure about what you do when you break down at night - probably just sleep until he repair boys turn up!
Interesting! Are there other NATO armies, which don’t use the blue flag?
Here is what I mentioned above on a truck of the German THW, which uses the same set of flags as the Bundeswehr.
Blue flag, all convoy vehicles except the last …
… green flag, last vehicle of a convoy …
… yellow flag, vehicle has technical problems …
… red flag, towing vehicle …
… of course the THW does not use red and green flags for live fire shooting …
Yeah me too and I don’t recall flags being used on convoys; but knowing me at the time (85’-87’) I most likely wasn’t paying attention lol. Definitely remember using them on the ranges.
Wow, a lot more flags, reflective stickers, and hi-vis items than we ever had in the 80s. Looks like the gun tubes are wrapped up in orange marking tape.
When we did convoys, we had escort vehicles at the front and back, the whoopie lights, and some (small) reflective stickers, and that was it. These photos are from 1982, we had just completed New Equipment Training on the then new M1 Abrams.
