I’m making a water base for a model. Waves are modeled with Das and airbrushed with Tamiya. I want to brush on clear acrylic varnish for final water effect, then, when thoroughly dry, spray with a clear gloss lacquer. Might there be any unfortunate disagreement between the acrylic varnish and the lacquer varnish?
Hi Leo,
All I can say is, BE CAREFUL, TEST FIRST!
On my Ryujo sea base the initial coat on the base was Tamiya acrylic blue with enamel paints for the wake. I was happy with the result.
Then I went back to touch it up and gloss coat with lacquer – with HIDEOUS results:
The lacquer was so “hot” it also attacked the underlying acrylic coat. The blue acrylic paint came apart in revolting, gelatinous sheets… UGH. Completely unsalvageable, I stripped the whole paint job away to the enamel primer (which the lacquer had also attacked) and had to start the painting completely again.
So again, BE CAREFUL, TEST FIRST!
Yeah. Thanks. Think I’ll finish up with the acrylic varnish.
and it was very nice looking base before the evil gloss coat.
