A lot of videos discuss this method but I’m having difficulty finding the construction foam that I can hot wire cut wit my Proxxen cutter.
Insulation foam, usually blue, or pink. Most DIY home repair stores carry it in 4’ x 8’ sheets. You can also find scraps and cut-offs at construction sites. Ask first!
I’ve always used the foam used to protect white goods & TVs, blocks of it often discarded in dumpsters etc. – a home-made hot-wire cutter works fine on it, the user wasn’t particularly proficient though…
This will never turn into anything interesting lol
Only teasing mate ![]()
Yep it nearly turned into…”Heydrich – On Ice!”
