Hi guys,
I was wondering what color spraycan to use in an Trumpeter Patriot Launcher.
Is it Humbrol 63, 93 or 237 ?
Or is it Tamiya TS3 or TS 46?
Anyone got the right answer ?
All are sandcolors in spraycans.
Gé
Hi guys,
Gé
A friend on here used Tamiya Wooden Deck Tan, XF78, and it loked surprisingly good.
Hi 18bravo,
Looked at this color, but is NOT available in spraycan.
Thanks anyway !
Gé
This has always been my favorite, but damn near impossible to find anymore. I decanter it and shoot it through my airbrush.
Would this work? I never bought it or tried it.
It is available in a spray can but is almost Sold Out; however, check the “Other sellers on Amazon” on the link on the bottom right of the webpage. @bankmannl
Aah, Tamiya ts-68, not xf-78 !
Gé
You’re correct, sorry about that.
Hi guys,
Since there is no good alternative paint for the modern Carc Tan I will use brush paint instead of a spraycan.
Thanks for all the suggestions !
Gé
We have had some things at work and the color has the very slightest pink hue. It’s not obvious and you really have to look.
Anyone else happen to notice this?
If you’re talking about Tamiya Wooden Deck Tan, what do you suggest I add, to subdue this pink hue you mentioned?
I’ve really struggled up here in W Canada to find a useable, reliable CARC tan, ( AK 3rd gen might be great but I can’t reliably thin and shoot it) I’d like to get the Tamiya product to look as *right as possible.
*(Knowing in many cases the equipment was painted using locally-available paint in the early stages of ODS).
Thanks!
See the pink hue in it Boots? Useable as CARC tan IYO ?
I really couldn’t say; I don’t model much stuff beyond 1989. I’ve used it as a base colour on around 4 x MASSTER-finished models and that’s about it; it was fine for those.
I would only put the tiniest amount of red in a mix. It can’t be obvious. It’s the kind of thing we would notice, but the average person probably wouldn’t.
The gear (I am sure I can’t say what it is) also is very matte, kind of coarse.
Thanks for that. I’m being a bit dumb here but, do you mean you’ve got some CARC - coloured equipment at work that has a slight pink tinge to it ?
I was thinking from your first post that the Tamiya Wood Deck Tan had a slight pink to it.
But now reading your reply, it I guess I’m wrong about that?![]()
Just a minor observation here: whilst we all like our models to look as accurate as possible, let’s not forget the scale colour effect. We’re (in 1:35) making something much smaller than the original; much as I appreciate fellow modelers’ zeal, I for one, don’t worry too much about the exact colour. Perhaps that makes me a slightly suspect modeller, but c’mon guys, don’t get too hung up given the scale effect.
This might seem heretical, but if it looks right is probably is(!)
I agree Brian, it’s certainly up to the modeler of course but for me, close enough is good enough.
At some recent model shows, I witnessed several different shades of CARC tan and the usual assortment of OD and Dark Yellows!
Point well made Brian! Given all the ‘brushing issues I’ve had with other brands of late, I’m going to lock in a carton of the Tamiya wooden deck tan and work with that in future.
Never had a problem with Tamiya acrylics so Hey Ho!
