What would be the Asuka equivalent to that kit? I’m wanting to build a USMC tank with the 55 gallon drum snorkels, and I want to see which kit is easier and cheaper to get.
Thanks guys
Isn’t that the one with welded driver’s hoods, made by Fisher? Then there is no Asuka equivalent. I don’t recall off the top of my head if the USMC also had non-Fisher M4A2s, but if so, then Asuka 35-018, Sherman III, would do.
Marine Shermans on Tarawa… look at the hull hatch extensions… also no wood planking used at that point on Marine tanks
The Lanmo conversion is exactly what I was going to get, that sucks about Asuka, but doing a bit more digging, it looks like the Dragon British Sicily Sherman Mk III may work too, but I’d have to source tracks , if I can find the kit. Different hoods on that Asuka Sherman III
Try out Panda Plastics for the tracks.
ETA: It seems Panda Plastics is offline for the time being.
Alternatively, you can square off the Asuka hoods with some plastic card and putty, build a Fisher-style antenna base, and do a few other small corrections.
FYI, best I recall only 3rd Tank batt. used these on Guam or Iwo Jima.
I’ll get this figured out, probably order the Dragon kit from China, this will be my birthday present to myself, so I can go a little wild with this one, that will keep things simple
A US option. Scalehobbyist.com: M4A2 Sherman Tarawa by Dragon Models
Regarding Tarawa
https://www.theshermantank.com/tag/tarawa/
That’s awesome, thanks for the link!!
There is a lot of pictures of the barrel set up on 3rd Marine Tank Battalion Sherman’s on Iwo Jima in the old Squadron book Tank Warfare on Iwo Jima.
David Harper (rip) book is a must if you want to build a Iwo Jima Sherman.
I have a bunch of Dave’s books, I’ll dig them out this weekend
