I’m looking for drawings or dimensions for the prism-shaped wheel chocks seen on East German / NVA vehicles:
What were these called by the NVA?
Thanks in advance,
KL
Thanks in advance,
KL
No idea on the name or dimensions but maybe this pic will help in it’s size?
Kurt, I believe the term is Unterlegkeile or Radvorleger; or at least that’s the term used on the MR Modellbau site - they make a different type amongst their products.
Their conversion set for the T-34/85 NVA however does include a couple of this type - and I used them on a BMP I was making. I’m not sure if the model is still in existence or hidden away somewhere - I’ll have a dig around.
I suppose an alternative would be to contact MR Modellbau but conceivably they might see you as competition(!)
I found this as well:
- = Model Type = - NVA Accessories - Railway loading wedges in 1/35 (modell-art.de)
I’m not sure if the tables within are for measurements of the chocks themsleves or for, say, placement (I just haven’t gotten around to translating them - the tables that is).
I should have paid more attention; this is actually an online shop site whereby the chocks themselves are available in 1:35 - amongst other products. Whether or not it’s still active I don’t know, but if so, then that might be the way ahead - prices appear reasonable.
Apologies for the somewhat scatter-gun response.
Länge = Length
Breite = Width
Höhe = Height
Masse = Weight / Mass
EVK Variant A For tracked vehicles with wide tracks, greater than and/or equal to 360mm.
EVK Variant A-W For tracked vehicles with wide tracks, greater than and/or equal to 360mm. These EVK’s had a stop edge welded on about 2cm from the edge.
EVK Variant B For tracked vehicles with narrow tracks, smaller than 360mm. These EVK’s had a stop edge welded on about 5 cm from the edge.
Link to shop:
Kurt,
The Unterlegkeile are present in Takoms T-55AM2B kit. I can measure them this evening, if that’s good enough
Angel
Fantastic, Robin & Brian! Much appreciated!
Thanks for the offer Angel, but I think I’m going to get the resin items.
KL
All thanks goes to Brian who knew where this stuff was.
I simply translated and Google did most of that work, since it was a straight forward text I trusted Google translate to get it right but I did proofread the result.
Well, it took both of your links for me to get both the explanation and buying pages until I went over everything a couple of times and went to the very bottoms!
Thanks again!
KL
