Like the work going into the tamiya one , always wanted a decent kit of this tank but couldn’t be bothered with what you’re doing for a decent model , good job.
Thanks. I’ve been in the same boat, but I think I’ve found my modeling niche, rescuing “pound puppies” of kits and doing refurbs on them. With all the “new” kits being superseded by “better” stuff now, there’s a lot of perfectly good material to work with that’s all of a sudden very reasonably priced.
And it’s fun.
But… I’m just itching to jump into one of the new Takom M48 kits.
Never got the Dragon kit but have some Takom kits, so I will be doing something similar with them and James Lee 3D parts I have.
Soon as ive finished the m-atv I will be tackling the old MLRS by dragon…not as involved as this hopefully.
Still plugging along, although progress will be really slow for a bit- I had carpal tunnel surgery yesterday that went so well I’m tempted to at least see how well the hand works… I can type, slowly.
Earlier in the week I got some turret bits on both, more on the Dragon kit using the DEF stowage and main gun.
IMG_3878 by Russel Baer, on Flickr
And on the Tamiya kit I have the mantlet details begun, with the searchlight mounts re-done to accept either an Academy or AFV Club light assembly. I’m also fudging in the mantlet cover
mounts.
IMG_3877 by Russel Baer, on Flickr
The tabs will be trimmed down as soon as they’re completely dry as they’re too wide now.
I also used Dragon tow cable ends on both turrets, with Karaya .6mm wire. Dragon supplies steel wire which stayed springy even after annealing, but I saved it thinking I might make up one more cable to be stowed ready-to-use on one of these two.
For now, I think I’ll clean up my bench a bit. It’s getting a little bit nasty.
Addendum: I found this box of goodies in the stash, very handy:
IMG_3880 by Russel Baer, on Flickr
Looking good and glad surgery went well… And you can’t beat a good fudge ![]()
I ordered some new Dremel bits from Amazon, and slowly thinned the undersides of the fenders until I could flex them with my fingers, then used a hair dryer to warm them enough to gently deform, using my fingers and small, smooth jaw pliers. I’m happy so far, so I began the process of adding the junk that’s on the fenders.
IMG_3882 by Russel Baer, on Flickr
IMG_3881 by Russel Baer, on Flickr
I thought about doing a bunch of detailing outboard of the front, long tool boxes, but when I found a bag full of old white metal 50-cal ammo boxes, I pulled up- no reason to go nuts on something I’m going to cover up. I’ll add some bolt heads towards the rear, but this will save some time.
Another neat little update Russ. Looks great. Where or who do you get your bolt heads from ? (the maker ) ![]()
I use a lot of bolt/washer and nut/washer combos from Meng and slices of hex rod stock. If it’s gray, it’s Meng, white is Plastruct hex rod.
Cheers Russ, and do you know what …I never even thought about hex rod … That’s a clever idea ![]()
How do you cut it the hex rod square?
Thanks, Dan
Can’t claim it as my own idea, but I jumped all over it. The smart guys use a miter cutter to get it cut perpendicular to the length, I cheap out and use a safety razor. I cut a bunch more pieces than I need, attach the best and use a fine sanding stick to get them all level, if necessary.
Thanks
The basic hull on the Model B is nearing completion, less stowage…
IMG_3883 by Russel Baer, on Flickr
Driver’s hatch is still off, there will be a half fig in there.
IMG_3884 by Russel Baer, on Flickr
Some epic building and detailing here Russ, looking forward to paint! Thanks for sharing!
Jimbo
Coming along great. Another great build with the surgery, extras and super detailing … lovely work Russ
Excellent work Russ, love the details and the hull sculpting.
Thanks all. It’s my happy place, massaging an old kit… plus I get to use up a bunch of leftovers.
Looking good, classic M48A3 both.
On the Magach 3 check the instructions for the PE parts added at the rear top of the turret, you might want to add those before the stowage. If you want reference photos I can post some
I do so like that term Russel, “massaging an old kit”; it’s often so redolent of what I do. My stash - assembled over the decades - contains those kits that have been long superseded by newer, and better versions, but being somewhat perverse, I tackle them and try and get the best from them, even though sometimes, I end up spending more than say, what a state-of-the-art kit would cost.
Anyway, that’s neither here nor there – keep up the good work with what you’re doing.
