HI !
Here another project I been working on these day , using the ESCI kit…If you like to view the complete WIP on this project , just follow this Google link :
photos.app.goo.gl/16gXQWKbDne45uwQ8
Enjoy !
Jmarc
HI !
Enjoy !
Jmarc
Here is the update on the project …
(JUL 30th ) Today , I continue adding detail of the front interior !
If you like to view the complete ‘WIP’ of this project , just follow this Google link !
Hope youl’le enjoy them !
Jmarc
Great work jmarc, I have two of these myself, that I’d like to use with a Skyraider, though I probably won’t detail mine as much as you have, I’m really curious as to how you constructed the lifting devise for the second vehicle your pictures are good but a diagram would be better.
Thanks, glad you like it …With a SKYRAIDER definitely a great ideal you have there , sadly I have’nt found diagram for it , I use picture that I have found on the net , it’s fairly easy and straight forward using strip of styrene , Looking forward to follow your build !.. GO,GO,GOOOOO
(AUG 05th ) Today , I completed the detail of the front interior and started the work of the front wheels details !
https://photos.app.goo.gl/16gXQWKbDne45uwQ8
Jmarc
(AUG 06th ) Today , I completed the basic structural details of the front wheels painted it with the wheels finally start to work the detail of the fork !
Jmarc
(AUG 07th ) Today , I glued the spacer in the bottom scissor section and stated the step over the front wheels !
Jmarc
(AUG 08th ) Today , I completed the second the step over the front wheels , painted the wheels and continue the work on the scissor lift !
Jmarc
(AUG 09th ) Today , I the work on the scissor lift !
Jmarc
(AUG 13th ) Today , I when true an road block and decided to glued the scissor arm to the lowest position , and painted the top plate !
Jmarc
(AUG 14th ) Today , I done the last details on the plate , painted ,wash /dry-brush the front section and finally glued the back wheels !
Jmarc
(AUG 15th ) Today , I add the front wheels and started to add the last details !
Jmarc
(AUG 16th ) Today , I start the last details !
Jmarc
(AUG 20th ) Today , I continue adding the decals !
Jmarc
(AUG 22th ) Today , I continue adding the decals !
Jmarc
(AUG 23th ) Today , I continue completed the decals and start the final assembly and details !
Jmarc
(AUG 28th ) Today , I continue working on the lfinal assembly and details !
Jmarc
(AUG 29th ) Today , I continue working on the final details !
Jmarc
(SEPT 03rd ) Today , I continue working on the final details !
Jmarc
(SEPT 04th ) Today , I continue working on the final details !
Jmarc
