I have this kit coming this week. Saw some kit decals for a USAFE unit with CR tail code stationed in the Netherlands, “Wolfhounds”. Sounds like a plan to me.
Does it have any weapons ?
I had an Hasegawa F-15 D/DJ that you needed to get a weapons set for it.
Zero missiles inside.
Can’t be sure about the fuel tanks, but no weapons there.
No weapons, 3 fuel tanks. I have 4 1/72 Hasegawa weapons sets but I really only use minimal missiles as a rule. I dislike painting tons of bombs and rockets. I always seem to knock them off somehow.
Most Hasegawa kits come without weapons. As you know to make a weapons set for those that want them.
A bit more work, jumping around a bit. Started the intakes and at the other end the exhaust nozzles. I still have 15 actuators to add to each nozzle.
Looking good. Seems like a nicely detailed cockpit area.
I sprayed the intake interiors light ghost gray as per the instructions and glued the halves together. I did a test fit of them on the upper fuselage and they fit almost perfect. They are not glued in, I need to sand the seam on the bottom and remove some errant flash.I must have lucked out as this old kit’s fit is simply amazing.
