Anyone got a real pic of these fat/wide tires on a Kubelwagen??
I’m not sure that they would fit. I’ve seen pictures the other way around, with Kubel tyres on a Schwimmwagen. However the sand tyres fitted to desert Kubels are a fatter section than the standard ones.
Ask Frenchy, he’s good at photo research!
They had no reason to put these tires on a Kubelwagen because it was only 2 wheel drive. The Shwimmwagen was 4 wheel drive and so benefitted from these “mudder” tires. The only alternative tires for the Kubelwagen are the balloon sand tires for the desert.
Dan…you are a Legend
Google is my tool
Dan I did about two hours searching on google/images and couldn’t find a pic. What did you type in to bring up that pic?? Thanks again you have been a great help
Yes, of course. The Americans had to throw a lift kit and big wheels under a 2WD ride.
Well it does look cooler
and will in 1/35 and 1/16
Captured kubelwagen
I’ve seen the pic before so I knew it was out there.
I don’t think that I’ve seen one in German service with fat tires however.
Could be wrong but I doubt they rushed out to put a new set of tires on. I’ll take it as the Germans adding them, it may have made the ride more comfortable
Well done Dan !
Thank you, but you are the master!
These guys seem to be mechanics so I bet they did put these tires on
Dan Dan Dan don’t say such things, the Germans made so many machines and one offs. I am sure one crazy German would of tested it and then three others. So I will build three as well…
Hell there are only one or two pics of some German machines that existed so I am pretty sure there weren’t pics taken of every Kubelwagen. Well that’s what I am going with
Thanks again Dan
And here. And I’m sure have seen at least a couple more during the last weeks of the war in Czechoslovakia but should dig a lot.
Now you have your German phatt tire pics.
