🔥🔩FAUSTUS MODELS FM25-010 | Panther Ausf. G Towing Cables — Aftermarket Quality from your Printer! 🖨️⚙️ | Armorama™
FM25-010 is a 1/35 Panther Ausf. G towing cables and towing hardware 3D print set for SLA printers, featuring true wire-rope strand-by-strand detail, correct end fittings, and a print-friendly spool layout with supported files included. Designed as a clean, high-impact aftermarket upgrade for the parts you actually see — compatible with all common Panther G kits.
This is partial text from the full article (usually with photos) at https://armorama.com/news/faustus-models-fm25-010-panther-ausf--g-towing-cables----aftermarket-quality-from-your-printer
Original for comparison :
( yes paint is original )
[img]https://i.imgur.com/jmD4Rvg.jpeg[/img]
[img]https://i.imgur.com/XBYCXFt.jpeg[/img]
[img]https://i.imgur.com/sJ606UQ.jpeg[/img]
Tip : The schackle pin has a thread. The cable end liner is just thin steel sheet filled with concrete.
Why don’t designers use the real things to make their job ?
Eric
Hi Eric, thanks for the comparison pics — much appreciated.
Just to clarify: the set includes two shackle types: the Panther shackle with a threaded pin (the thread is modeled) and a heavier shackle with a plain pin. Regarding the “cable end liner”: the ferrule/sleeve is potted, but not fully solid all the way to the end (which is not uncommon), so you still see a bit of internal void/transition for extra visual detail.
