Hello everyone,
I started to assemble this Tamiya kit:
by Rodolfo Masti, on Flickr
to make the Fw 190 D-9 jv 44 Sachsenberg Schwarm - “Red 1” flown by Leutnant Heinz Sachsenberg
A quick look inside the box:
First steps …
Plane assembled and ready for the primer …
Painting wings’ undersurfaces …
I began the complex task of painting camouflage … My hope is to be able to do an acceptable job …
I don’t know about painting aircraft. Did you do the whole upper surface in the lighter green and then the panel lines in a darker green or the other way around??? Do you still do a darker wash later?
What do you think of it?
Looking quite good! Very striking aircraft.
Ready for weathering …
The canopy is simply leaning, I have yet to decide whether to leave it closed or open …
Bravo! an absolute stunner.
You’ve done a grand job of that camo and the overall finish is excellent.
Watto
Plane ready for take-off …
Looks great! Very striking.
Was there a tactical reason for the underside color, or was it just that it was not seen when the plane was on the ground?
Thanks, I suspected as much, but not knowing much about aircraft, I didn’t want to assume.
Hello,
For more information take a look at this website
Here is a small excerpt from the page linked above:
Protection squadron - Die Würger-Staffel
Because of the greater length of runway it required, and the slow acceleration it had at low speeds, the Me 262 was especially vulnerable during take-off and landing. Galland thus established his own protection flight. Five Fw 190D-9s and D-11s were attached to JV44, the Platzschutzstaffel (Airfield protection squadron), headed by Leutnant Heinz Sachsenberg, to provide air cover for takeoffs and landings. Flights were to be undertaken in a two-aircraft Rotte up to altitudes of 500 metres, covering both the Me 262s taking off or landing and monitoring the surrounding skies for Allied fighters.
The Platzschutzstaffel flew the long-nosed ‘Dora’, Fw-190 D-9, or Fw-190 D-11 variant of the well-known Fw 190. These aircraft were painted bright red on their wings’ undersurfaces with contrasting white stripes so anti-aircraft batteries could distinguish them from Allied piston-engined aircraft, leading to their humorous postwar nickname of the Papagei Staffel (Parrot squadron). The Staffel was nicknamed “Die Würger-Staffel”, a play on the common nickname for the BMW 801 radial-engined original A-version of the Fw 190, which was Würger or Butcher-bird. [/i]
Citroen 11 CV Staff Car
Nice work. what rlm colors did you use for the greens?
thanks-
Joe
Nice! I got the eduard combo to do on the JV 44 (red 2 for the D11, not sure about the D9 yet).I plan to use J-C mermet book on luftwaffe color schemes as documentation with the jerry crandall volume.
