German Gas welder
Hi all,
What should be the right color for the 2 gas bottles (acetylen and oxygen) used for the welder please?
Thanks for your help
Nowadays, Oxygen bottles are blue and Acetylene green. CanÂŽt about tell WW2 but probably the same.
According to the manufacturer, this 1/6th scale set has been “properly researched”
But the Miniart guys appear to differ
https://miniart-models.com/wp-content/uploads/2020/03/35618-instruction.jpg
https://miniart-models.com/wp-content/uploads/2020/07/35359_instr.pdf
https://miniart-models.com/wp-content/uploads/2019/03/35591_instruction.pdf
PS : welcome to (the new) Armorama Pierre :wink:
It seems that only period photos will help here.
From ou very own Grumpyoldman :wink:
Salut Frenchy,
Je prĂ©fĂ©rai l’ancienne version !
If I cross all I found yes definitly Oxygen is blue.
In fact tanks could be maroon overall with only a coloured stripe on top.
Yellow seems to be the correct colour for Acetylene.
Someone shared this picture with me :
By the way, this Mininiart kit is the one I’m building on :slight_smile:
More welding accessories :
Great !
merci Frenchy
You’re welcome ! More info about these tools :
http://usmbooks.com/nazi_MV_tool_set.html
Messer-Griesheim company is still in the gas-welding/cutting business.
https://www.schweiss-shop.de/messer-griessheim
A little history on gas welding.
https://en.wikipedia.org/wiki/Oxy-fuel_welding_and_cutting
Just want to say thanks for the great pictures and great information. Putting together a Werkstat company, have a lot of repair tools including gas bottles, and this will make it much better.
DAKjunkie
Must be different from different companies as acetylene is black and oxygĂšne is green the welding shops I’ve worked at and I even have my own set in my garage. So I wonder if this could have been the case during WW2? Not to mention looting if left behind equipment. Ror instance the diorama I am building is a scene imagined to have happened during the long fighting retreat the Germans made after D-Day. an Opal Blitz (clearly a very early model pressed back into service as it’s original dunklegrau paint is showing through the late war dunklegelp hurredly field sprayed) doing some custom welding on a newly arrived Bergepanther both from the the heavy repair unit of the 116th Panzer Division while the repair is being depicted as a technician just starting to respray the camo pattern around the welds the Bergepanther ́crew is refueling from to barrels on a single axle trailer the Opal has in tow. While near by a swimmwagon from the first SS arrives loaded with luxury items while an ss lieutenant wishing to do some bartering for fuel from a heer captain from the 116th he notices using the equipment and parts on the Opel there are 4 more fuel barrels along with a keg of “liberated” schnapps and basket of fresh ́potatoes so when the captain accepts the offer of a cigarette to smoke while they talk he declines the offer of some cartons of cigarettes, french vine even some absolutely sought after Pervatin (that while now hooked on by much of the German army is only sporadically arriving at the front lines) at which point, and the the point of my long story, the ss lieutenant very coldly and boldly ́points out that the schnapps is against the rules to be drinking and then his ace in the hole he ́points out the visible helmet painted on the trailer and that it might be uncomfortable explaining to higher ups why they are in possession of a “stolen” trailer and most likely the fuel as well. I have found out information on the units around and actions during the retreat and that discarding equipment for one reason or another (in this case it was a broken hitch
an added detail I just came up with when I broke the hitch while removing it from the 3d printer parts block lol) was common and so was repairing and or repurposing found or discarded equipment and supplies and how often old vehicles and rear guard vehicles may have still been dunklegrau and pressed back into service and given to front line units who would need to respray them in a hurry. I’ve found info on the welder and paint sprayer the types of looted and horded supplies because of shortages even that there was not only tension between the ss units and the heer units but that that prĂ©fĂ©rentiel treatment was give to the SS when supplies did come
but I’ve had a hard time finding agreement on what colours the gas bottles should be but the consensus is they where both painted maroon with a yellow and blue shoulders to denote the type of gas.
